Hi Guys.
I am student from Vietnam
I received a RFID Module from my friend. I have used RFID from link: GitHub - miguelbalboa/rfid: Arduino RFID Library for MFRC522
I have complied and download a example from this libary. I tried with DumpInfo.
But It said that: Communication Failure?
I use Arduino Mega.
here is pinout:
RST------------5
SS-------------53
SCK------------52
MOSI----------51
MISO----------50
I changed SS and RST Configure follow this:
#define RST_PIN 5 //
#define SS_PIN 53 //
Here is my full code:
* This is a MFRC522 library example; see https://github.com/miguelbalboa/rfid
* for further details and other examples.
* NOTE: The library file MFRC522.h has a lot of useful info. Please read it.
* Released into the public domain.
* Example sketch/program showing how to read data from a PICC (that is: a RFID
* Tag or Card) using a MFRC522 based RFID Reader on the Arduino SPI interface.
* When the Arduino and the MFRC522 module are connected (see the pin layout
* below), load this sketch into Arduino IDE then verify/compile and upload it.
* To see the output: use Tools, Serial Monitor of the IDE (hit Ctrl+Shft+M).
* When you present a PICC (that is: a RFID Tag or Card) at reading distance
* of the MFRC522 Reader/PCD, the serial output will show the ID/UID, type and
* any data blocks it can read. Note: you may see "Timeout in communication"
* messages when removing the PICC from reading distance too early.
* If your reader supports it, this sketch/program will read all the PICCs
* presented (that is: multiple tag reading). So if you stack two or more
* PICCs on top of each other and present them to the reader, it will first
* output all details of the first and then the next PICC. Note that this
* may take some time as all data blocks are dumped, so keep the PICCs at
* reading distance until complete.
* Typical pin layout used:
* MFRC522 Arduino Arduino Arduino Arduino Arduino
* Reader/PCD Uno Mega Nano v3 Leonardo/Micro Pro Micro
* Signal Pin Pin Pin Pin Pin Pin
* RST/Reset RST 9 5 D9 RESET/ICSP-5 RST
* SPI SS SDA(SS) 10 53 D10 10 10
* SPI MOSI MOSI 11 / ICSP-4 51 D11 ICSP-4 16
* SPI MISO MISO 12 / ICSP-1 50 D12 ICSP-1 14
* SPI SCK SCK 13 / ICSP-3 52 D13 ICSP-3 15
#include <SPI.h>
#include <MFRC522.h>
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance
Serial.begin(9600); // Initialize serial communications with the PC
while (!Serial); // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522
ShowReaderDetails(); // Show details of PCD - MFRC522 Card Reader details
Serial.println("Scan PICC to see UID, type, and data blocks...");
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent()) {
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial()) {
return;
// Dump debug info about the card; PICC_HaltA() is automatically called
mfrc522.PICC_DumpToSerial(&(mfrc522.uid));
void ShowReaderDetails() {
// Get the MFRC522 software version
byte v = mfrc522.PCD_ReadRegister(mfrc522.VersionReg);
Serial.print("MFRC522 Software Version: 0x");
Serial.print(v, HEX);
if (v == 0x91)
Serial.print(" = v1.0");
else if (v == 0x92)
Serial.print(" = v2.0");
Serial.print(" (unknown)");
Serial.println("");
// When 0x00 or 0xFF is returned, communication probably failed
if ((v == 0x00) || (v == 0xFF)) {
Serial.println("WARNING: Communication failure, is the MFRC522 properly connected?");
what wrong? Please tell me!
Thanks for reading
