RFID RC522 Door opener
Hello,
I need help!
I always get this error message:
fatal error: pitches.h: No such file or directory
#include <pitches.h>
compilation terminated.
exit status 1
#include expects "FILENAME" or
May someone helps me?
  • RFID Module RC522
  • Simple Project:- Arduino will read RFID Tag and Display To the Serial Monitor!
  • RFID RC522 and Arduino Uno Pin Configuration
  • RFID RC522 Arduino Uno
  • SS/SDA D10
  • SCK D13
  • MOSI D11
  • MISO D12
  • IRQ Not Connected
  • GND GND
  • RST D9
  • 3.3V 3.3V
  • //Note: We connected LCD to the Analog Pins.
  • Remember, Analog Pins can be act as a Digital Pins,
  • But Digital Pins CAN NOT be act as a Analog Pins.
  • LCD(16x2) Connections
  • VSS pin to GND
  • VCC pin to 5V
  • //We are connecting "Contrast pin to GND for Maximum Brightness"
  • //You can also connect it to 10K Pot if you wish to change the Brightness Of LCD.
  • VEE pin to GND
  • RS pin to Analog pin A0
  • R/W pin to ground
  • Enable pin to Analog pin A1
  • D4 pin to Analog pin 5
  • D5 pin to Analog pin 4
  • D6 pin to Analog pin 3
  • D7 pin to Analog pin 2
  • LED+ pin to POWER
  • LED- pin to GND
  • Servo is Connected to Digital Pin 5
  • RGB LED
  • From RGB LED, We need Only Red and Green Color,
  • So we are not connecting Blue pin of the RGB.
  • Red pin to Digital pin 6
  • Green pin to Digital pin 7
  • Buzzer to Digital pin 8
  • Note:- RFID uses SPI Protocol to transfer the information.
  • I took the Melody(for the Buzzer) from,
  • File -> Examples -> Digital -> ToneMelody
//Include sections
#include MFRC522.h.
#include <SPI.h>
#include <LiquidCrystal.h>
#include <Servo.h>
//Define Component to Arduino Pins
#define SS_PIN 10
#define RST_PIN 9
#define SERVO_PIN 5
#define Red_LED 6
#define Green_LED 7
#define Buzzer 8
//initialize the library with the numbers of the interface pins
LiquidCrystal lcd(A0, A1, A2, A3, A4, A5);
Servo DoorLock;
MFRC522 rfid(SS_PIN, RST_PIN );
//Unique ID of RFID Tag, which you want to give access.
int My_RFID_Tag[5] = {0x58,0x76,0x17,0x10,0x29};
//variable to hold your Access_card
boolean My_Card = false;
// notes in the melody, taken from:
//File -> Examples -> Digital -> ToneMelody
int melody[] = {
NOTE_C4, NOTE_G3, NOTE_G3, NOTE_A3, NOTE_G3, 0, NOTE_B3, NOTE_C4
// note durations: 4 = quarter note, 8 = eighth note, etc.:
int noteDurations[] = {
4, 8, 8, 4, 4, 4, 4, 4
//set the pins as an input/output
pinMode(Red_LED,OUTPUT);
pinMode(Green_LED,OUTPUT);
pinMode(Buzzer,OUTPUT);
//Servo Connnected to pin Digital Pin 5
DoorLock.attach(SERVO_PIN);
//open the serial port at 9600 baudrate.
//Initialise the LCD to 16x2 Character Format
lcd.begin(16,2);
//Initialise Servo and RFID
SPI.begin();
rfid.PCD_Init();
//First Assume detected card(Or tag) is My_Card,
//Then later we will check is it My_Card or not!
My_Card = true;
DoorLock.write(0); //Servo at 0 Position, Door is Closed.
lcd.clear();
lcd.print("Robodia Technology");
lcd.setCursor(0,1);
lcd.print("gy Solutions!");
//Check if any RFID Tags Detected or not?
if( rfid.PICC_IsNewCardPresent() )
//if RFID Tag is detected, check for the Unique ID,
//and print it on the Serial Window
if( rfid.PICC_ReadCardSerial() )
lcd.clear();
lcd.print("UNIQUE ID is:- ");
lcd.setCursor(0,1); //Set LCD Cursor to Second Row, First Character
  //Unique id is 5 Digit Number.
      //Printing in HEX for better Understanding
      for( int i = 0; i < 5; i++ )
          Serial.print(rfid.uid.uidByte[i], HEX);
          Serial.print(" ");
          lcd.print(rfid.uid.uidByte[i],HEX);
          lcd.print(" ");
  //Compare this RFID Tag Unique ID with your My_RFID_Tag's Unique ID
      for(int i = 0; i < 5; i++)
          //if any one Unique ID Digit is not matching,
          //then make My_Card = false and come out from loop
          //No need to check all the digit!
          if( My_RFID_Tag[i] != rfid.uid.uidByte[i] )
            My_Card = false;
      //If RFID Tag is My_Card then give access to enter into room
      //else dont open the door.
      if(My_Card)
        Serial.println("\nWelcome To Your Room, Robodia!");
        lcd.clear();
        lcd.print("Welcome to Your");
        lcd.setCursor(0,1);
        lcd.print("Room, Robodia!");
        delay(2000);
        //Turn on the Green LED as an indication of permission is given
        //to access the room.
        digitalWrite(Green_LED,HIGH);
        //Buzzer Config, taken from:
        // iterate over the notes of the melody:
        int i = 0;
        while(i < 2)
          for (int thisNote = 0; thisNote < 12; thisNote++)
            // to calculate the note duration, take one second
            // divided by the note type.
            //e.g. quarter note = 1000 / 4, eighth note = 1000/8, etc.
            int noteDuration = 1000 / noteDurations[thisNote];
            tone(8, melody[thisNote], noteDuration);
            // to distinguish the notes, set a minimum time between them.
            // the note's duration + 30% seems to work well:
            int pauseBetweenNotes = noteDuration * 1.30;
            delay(pauseBetweenNotes);
            // stop the tone playing:
            noTone(8);
          i =  i + 1;
        //Now, Open the Door with the help of Servo Motor
        DoorLock.write(180);
        delay(200);
        lcd.clear();
        lcd.print("Door is Open");
        lcd.setCursor(0,1);
        lcd.print("Now!");
        delay(2000);
        lcd.clear();
        //Give 10 Sec delay to enter into room
        //After that door will again closed!
        for(int i = 10; i > 0; i--)
          lcd.print("Door will close");
          lcd.setCursor(0,1);
          lcd.print("in ");
          lcd.print(i);
          lcd.print(" Sec.HurryUp!");
          lcd.clear();
        //Now,Door is closed and Green LED is Turned-Off.
        DoorLock.write(0);
        digitalWrite(Green_LED,LOW);
        delay(200);
        lcd.clear();
        lcd.print("Door is Close");
        lcd.setCursor(0,1);
        lcd.print("Now!");
        delay(2000);
      // If RFID Tag is not My_Card then
      // Do not open the Door and
      //Turn-On Red LED and Buzzer as an indication of Warning:
      //Somebody else is trying to enter into your room.
        Serial.println("\nGet Out of Here !");
        lcd.clear();
        lcd.print("Card isNOT FOUND!");
        lcd.setCursor(0,1);
        lcd.print("Get Out of Here!");
        for(int i = 0; i < 7; i++)
          digitalWrite(Buzzer, HIGH);
          digitalWrite(Red_LED,HIGH);
          digitalWrite(Buzzer, LOW);
          digitalWrite(Red_LED,LOW);
//Put RFID Reader into Halt, untill it not detects any RFID Tag.
rfid.halt();
kind regards
It just means you're missing whatever library contains pitches.h. You will need to install it.
I think it is the tone library.
A post was split to a new topic: Program intermittently freezes after relay is energized
