OLÁ ESTOU COM UM PROBLEMA COM MEU CÓDIGO, ESTOU TENTANDO ENVIAR AS TAGS DO RFID PARA UMA PÁGINA HTML COM AJAX, ESTÁ FUNCIONANDO PARCIALMENTE N SEI QUAL ERRO ESTOU COMETENDO, NA PAGINA HTML AJAX RECEBE AS TAGS DE FORMA LENTA E N COMPLETA E AS VEZES ELA SE MISTURAM, SEGUE MEU CÓDIGO DO ARDUINO E A PAGINA HTML COM AJAX, AGRADEÇO MTO QUEM PUDER ME AUXILIAR!
#include <SPI.h>
#include <Ethernet.h>
#include <MFRC522.h>
#define SS_PIN 53
#define RST_PIN 49
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
IPAddress ip(192,168,0,150);
IPAddress gateway(192,168,0,1);
IPAddress subnet(255,255,255,0);
EthernetServer server(8090);
char st[20];
String tag= "";
String conteudo= "";
byte letra;
Serial.begin(9600); // Inicia a serial
Serial.println("Iniciando programa..");
Ethernet.begin(mac,ip,gateway,subnet);
Serial.println("Servidor ativo no IP: ");
Serial.println(Ethernet.localIP());
mfrc522.PCD_Init(); // Inicia MFRC522
server.begin();
SPI.begin(); // Inicia SPI bus
Serial.println("Aproxime o seu cartao do leitor...");
void loop(){
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial())
return;
for (byte i = 0; i < mfrc522.uid.size; i++){
Serial.print(mfrc522.uid.uidByte[i]);
tag += String(mfrc522.uid.uidByte[i]);
if(client){
boolean continua = true;
while(client.connected()){
if(client.available()){
client.println("Content-Type: text/javascript");
client.println("Access-Control-Allow-Origin: *");
client.println();
client.print("dados({ tag : ");
client.println(tag);
client.print(",");
client.print("})");
delay(1);
client.stop();
delay(1500);
AQUI É O HTML COM AJAX:
<!DOCTYPE HTML>
<html>
<head>
<title>Arduino com AJAX</title>
<meta charset="utf-8" />
<meta name="viewport" content="width=device-width, initial-scale=1">
<!-- <script src="http://ajax.googleapis.com/ajax/libs/jquery/1.11.0/jquery.min.js"></script>-->
<script src="js/jquery.js"></script>
<link rel="stylesheet" href="http://netdna.bootstrapcdn.com/bootstrap/3.1.1/css/bootstrap.min.css">
<link rel="stylesheet" href="http://netdna.bootstrapcdn.com/bootstrap/3.1.1/css/bootstrap-theme.min.css">
<script src="http://netdna.bootstrapcdn.com/bootstrap/3.1.1/js/bootstrap.min.js"></script>
<script type="text/javascript" src="https://www.google.com/jsapi"></script>
<style type="text/css">
.clean { padding: 0; margin: 0;}
</style>
</head>
<body>
<div class="container">
<div class="row">
<div class="col-md-3 well">
<p>
Status: <span id="status" class="label"></span>
</p>
<p>
<h4>TAG:<span></span></h4>
</p>
<span id="tag"></span>
</div>
</div>
</div>
<script type="text/javascript">
//AQUI É A CONFIGURAÇÃO DO IP DO ARDUINO
var url = 'http://192.168.0.150:8090';
$(document).ready(function(){//AQUI É A FUNÇÃO DE CLICK PARA ENVIO
var i = 0;
function fazerRequisicao(){//AQUI É A FUNÇÃO QUE RECEBE OS DADOS DO ARDUINO
$('#status').removeClass('label-success').addClass('label-warning');
$('#status').text("Enviando Requisição...");
$.ajax({
url: url,
dataType: 'jsonp',
crossDomain: true,
jsonp: false,
jsonpCallback: 'dados',
success: function(data,status,xhr) {
$('#status').removeClass('label-warning').addClass('label-success');
$('#status').text("Requisição Recebida!");
$('#tag').text(data.tag);
i++;
console.log(data);
return false;
setInterval(fazerRequisicao, 2000);
</script>
</body>
</html>
