RFID RC522 + NODEMCU ESP8266 + LOCALHOST
hello guys, I’m working on a school project on iot, which is based on RFID RC522 and nodemcu (esp8266) and using a wamp server to connect to localhost, but I have a problem the data is not sent to localhost (trying to read cards validating date on localhost) and I do not know how to solve this, if you can help me I would be very grateful.
*my system:
  1. RFID RC522 + NODEMCU RESP8266 (WIFI)
  2. On my laptop I’m running the following configuration of XAMPP
Apache 2.4.35
MySQL 5.7.23
PHP 7.2.10
  1. Arduino IDE
*source code on arduino is the following :
 #include<SoftwareSerial.h>
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include <SPI.h>
#include <MFRC522.h>
const char* ssid = "Tenda";
const char* password = "*******";
//WiFiClient client;
char  server[] = "192.168.5.8"; //YOUR SERVER
//const char* server="www.google.com";
#define SS_PIN D4 //FOR RFID SS PIN BECASUSE WE ARE USING BOTH ETHERNET SHIELD AND RS-522
#define RST_PIN D8
#define No_Of_Card 3
#define LED_PIN D2
#define LED_CIN D1
WiFiClient client;
//WiFiServer server(80);
SoftwareSerial mySerial(8,9);
MFRC522 rfid(SS_PIN,RST_PIN);
MFRC522::MIFARE_Key key;
byte id[No_Of_Card][4]={
//{16,102,192,73}, //RFID NO-1 1
{188,32,7,133}, //RFID NO-2
{224,43,39,27}//RFID NO-3
byte id_temp[3][3];
byte i;
int j=0;
void setup(){
  SPI.begin();
   rfid.PCD_Init();
   pinMode(LED_PIN,OUTPUT);
  pinMode(LED_CIN,OUTPUT);
for( byte i=0;i<6;i++){
key.keyByte[i]=0xFF;
// Connect to WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
// Start the server
//Server.begin();
Serial.println("Server started");
Serial.print(WiFi.localIP());
Serial.println("connecting...");
{ // Check if a client has connected
int m=0;
if(!rfid.PICC_IsNewCardPresent())
return;
if(!rfid.PICC_ReadCardSerial())
return;
for(i=0;i<4;i++)
id_temp[0][i]=rfid.uid.uidByte[i];
delay(50);
for(i=0;i<No_Of_Card;i++)
if(id[i][0]==id_temp[0][0])
if(id[i][1]==id_temp[0][1])
if(id[i][2]==id_temp[0][2])
if(id[i][3]==id_temp[0][3])
Serial.print("your card no :");
for(int s=0;s<4;s++)
Serial.print(rfid.uid.uidByte[s]);
Serial.print(" ");
Serial.println("\nVALID");
digitalWrite(LED_PIN,HIGH);
delay(400);
digitalWrite(LED_PIN,LOW);
Sending_To_DB();
j=0;
rfid.PICC_HaltA(); rfid.PCD_StopCrypto1(); return;
{j++;
if(j==No_Of_Card)
Serial.println("inVALID");
digitalWrite(LED_CIN,HIGH);
delay(400);
digitalWrite(LED_CIN,LOW);
//Sending_To_DB();
j=0;
// Halt PICC
rfid.PICC_HaltA();
// Stop encryption on PCD
void Sending_To_DB() //CONNECTING WITH MYSQL
if (client.connect(server,80)) {
Serial.println("connected");
// Make a HTTP request:
Serial.println("GET miniprojet/rfid/rfid_read.php?allow="); //YOUR URL/rfid/rfid_read.php?allow
client.print("GET /rfid/nodemcu_rfid/rfid_read.php?allow="); //YOUR URL/rfid/rfid_read.php?allow /var/www/html/rfid/rfid_read.php
if(j!=No_Of_Card)
Serial.println('1');
client.print('1');
Serial.println('0');
client.print('0');
Serial.println("&id=");
client.print("&id=");
Serial.println(rfid.uid.uidByte[s]);
client.print(rfid.uid.uidByte[s]);
client.print(" "); //SPACE BEFORE HTTP/1.1
client.print("HTTP/1.1");
client.print("Host: ");
client.println(server);
client.println("Host:  192.168.5.8");
client.println("Connection: close");
client.println();
// if you didn't get a connection to the server:
Serial.println("connection failed");
client.stop();
Why do your Serial and client print() statements not match?
How many Host statements are needed?
Why are you COMPLETELY ignoring what the server has to say? I suppose you’ll ignore us, too.
If you are running your own Apache server, why are you not looking at the log files it produces. Perhaps a clue-by-four would whack you, if you did.
Serial and client print() statements to read the php files that are responsible for transmiting data to database at localhost , and i'm not used to electronic cards it's my first project using nodemcu, and i really need help please i don't know what to do, i've just found these statements on internet and i've tried to put things together, the rfid code does work but it seems that i can't connect to the server, and i have no idea why
it always say connection failed
You clearly haven't a clue what localhost means, so stop using that term.
Why didn't you say THAT in the first place?
Can you connect to 192.168.5.8 from another PC in the 192.168.5.n subnet?
I
tried
again
to
read
your
code,
but
I gave
up.
Use Tools + Auto Format to properly indent your code.
thanks for your time, i appreciate it
