RFID-RC522 Only reading 4 characters correctly
Recently I have been working on a project using NFC, I have run into a problem, it only successfully reads 4 characters and the rest are incorrect. The code I have written so far is:
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN         9          // Configurable, see typical pin layout above
#define SS_PIN          10         // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN);
MFRC522::MIFARE_Key key;
  SPI.begin();
  mfrc522.PCD_Init();
  for (int i = 0; i < 6; i++)
    key.keyByte[i] = 0xFF;
  if (!mfrc522.PICC_IsNewCardPresent()) return;
  if (!mfrc522.PICC_ReadCardSerial()) return;
  byte len = 64;
  byte buffer[64];
  byte block = 4;
  mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, 4, &key, &(mfrc522.uid));
  MFRC522::StatusCode status = mfrc522.MIFARE_Read(4, buffer, &len);
  if (status != MFRC522::STATUS_OK) {
    Serial.print(F("Reading failed: "));
    Serial.println(mfrc522.GetStatusCodeName(status));
    return;
  bool print = false;
  for (uint8_t i = 0; i < 64; i++)
    if (buffer[i] == 0x7D) break;
    if (buffer[i] == 0x7B)
      print = true;
      continue;
    if (print == true) Serial.write(buffer[i]);
  //TODO move read to function to make code neater
  Serial.write("\n");
  mfrc522.PICC_HaltA();
  mfrc522.PCD_StopCrypto1();
The library I am using is the MFRC522 library by Miguel Balboa
The Information I have written to the card is the following:
Record 0: {Anthony}
When read I get the output: Anthp⸮⸮
Thanks In advance
