RFID-RC522
I have been working all day to figure this out. i belave it is a software problim to hardware.
the RDID is not scaning for some reason.
this is the code.
http://www.instructables.com/files/orig/F0R/4L0P/IO7GSDW5/F0R4L0PIO7GSDW5.ino
this is what shoes up on the serial monitor.
BlueCore Tech Acces Control
MFRC522 Version: 0x92 (unknown)
No Master Card Set
Scan A RFID Card to Set as Master Card
Do you have your RFID reader hooked up exactly as shown in the code?
	We need to define MFRC522's pins and create instance
	Pin layout should be as follows (on Arduino Uno):
	MOSI: Pin 11 / ICSP-4
	MISO: Pin 12 / ICSP-1
	SCK : Pin 13 / ICSP-3
	SS : Pin 10 (Configurable)
	RST : Pin 9 (Configurable)
	look MFRC522 Library for
	other Arduinos' pin configuration
Do you supply it with power and ground?
