rfid read if function not working
Hi!
I have the following code.
And when tag1 is detected i want the door to open.
But no matter what i try the if function is never getting true :frowning:
I tried putting \n and \r behind it but also no result
  Parallax RFID Reader: Basic Demonstration
  Author: Joe Grand [www.grandideastudio.com]
  Contact: support@parallax.com
  Program Description:
  This program provides a simple demonstration of the Parallax RFID Card
  Reader (#28140). If a valid RFID tag is placed in front of the reader,
  its unique ID is displayed in the Arduino Serial Monitor.
  Please refer to the product manual for full details of system functionality
  and capabilities.
  Revisions:
  1.0 (April 30, 2014): Initial release
// include the SoftwareSerial library so we can use it to talk to the RFID Reader
//#include <SoftwareSerial.h>
#define enablePin  9   // Connects to the RFID's ENABLE pin
//define rxPin      10  // Serial input (connects to the RFID's SOUT pin)
//#define txPin      11  // Serial output (unused)
#define BUFSIZE    11  // Size of receive buffer (in bytes) (10-byte unique ID + null character)
#define RFID_START  0x0A  // RFID Reader Start and Stop bytes
#define RFID_STOP   0x0D
// set up a new serial port
//SoftwareSerial rfidSerial =  SoftwareSerial(rxPin, txPin);
void setup()  // Set up code called once on start-up
  // define pin modes
  pinMode(enablePin, OUTPUT);
 // pinMode(rxPin, INPUT);
  digitalWrite(enablePin, HIGH);  // disable RFID Reader
  // setup Arduino Serial Monitor
  while (!Serial);   // wait until ready
  Serial.println("\n\nParallax RFID Card Reader");
  // set the baud rate for the SoftwareSerial port
  Serial1.begin(2400);
  Serial.flush();   // wait for all bytes to be transmitted to the Serial Monitor
void loop()  // Main code, to run repeatedly
    When the RFID Reader is active and a valid RFID tag is placed with range of the reader,
    the tag's unique ID will be transmitted as a 12-byte printable ASCII string to the host
    (start byte + ID + stop byte)
    For example, for a tag with a valid ID of 0F0184F07A, the following bytes would be sent:
    0x0A, 0x30, 0x46, 0x30, 0x31, 0x38, 0x34, 0x46, 0x30, 0x37, 0x41, 0x0D
    We'll receive the ID and convert it to a null-terminated string with no start or stop byte.
  digitalWrite(enablePin, LOW);   // enable the RFID Reader
  // Wait for a response from the RFID Reader
  // See Arduino readBytesUntil() as an alternative solution to read data from the reader
  char rfidData[BUFSIZE];  // Buffer for incoming data
  char offset = 0;         // Offset into buffer
  rfidData[0] = 0;         // Clear the buffer
  while(1)
    if (Serial1.available() > 0) // If there are any bytes available to read, then the RFID Reader has probably seen a valid tag
      rfidData[offset] = Serial1.read();  // Get the byte and store it in our buffer
      if (rfidData[offset] == RFID_START)    // If we receive the start byte from the RFID Reader, then get ready to receive the tag's unique ID
        offset = -1;     // Clear offset (will be incremented back to 0 at the end of the loop)
      else if (rfidData[offset] == RFID_STOP)  // If we receive the stop byte from the RFID Reader, then the tag's entire unique ID has been sent
        rfidData[offset] = 0; // Null terminate the string of bytes we just received
        break;                // Break out of the loop
      offset++;  // Increment offset into array
      if (offset >= BUFSIZE) offset = 0; // If the incoming data string is longer than our buffer, wrap around to avoid going out-of-bounds
  Serial.println(rfidData);       // The rfidData string should now contain the tag's unique ID with a null termination, so display it on the Serial Monitor
  Serial.flush();                 // Wait for all bytes to be transmitted to the Serial Monitor
int code = rfidData;
int data = "4F0054AE69";
if (code == data ){
  Serial.println("bam");
  Serial.println("nope");
There are 5 if "functions" (they are statements) in your code. Which one is never true?
So, you stored the address of the rfidData array in an integer variable.
Now, you are storing the address of another memory location in another variable.
Then, you are trying to determine if the two addresses are the same.
That is NOT how to do that.
char *validData = "4F0054AE69";
if(strcmp(validData, rfidData) == 0)
   // Hey, the tag is valid
It was the last one...
Did the job!!
Thanks a lot!!
You made my day!
