RFID read problem
Hello everyone, I'm new in building Arduino codes and I have a problem with data read.
I use Arduino Mega 2560 and RFID module from Elechouse (http://www.elechouse.com/elechouse/images/product/13.56MHZ_RFID_Module/13.56MHZ_RFID_Manual.pdf
I used the code sample from Elechouse:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3); //pin2 Rx, pin3 Tx
int CMD[64]; // Here the Max command length is set as 64 bytes. For example, Command “AB 02 01” is 3 bytes
int comlen =0;
int out_flag =0;
  mySerial.listen();
  Serial.println("Serial number will be displayed here if a card is detected by the module:\n");
  // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);
  delay(10);
  mySerial.write(0x02); //Send the command to read RFID tag, please refer to the manual for more detail.
void loop() // run over and over
  while (Serial.available())
    int a = SerialReadHexDigit();
    //Serial.println(a);
    if(a>=0){
      CMD[comlen] = a;
      comlen++;
    delay(10);
  for(int i=0; i<comlen; i+=2){
    int c = mySerial.write( CMD[i]*16 + CMD[i+1]); //Convert Hex Characters in to Hex number, and send it to RFID.
  comlen =0;
  while (mySerial.available()) {
    byte C = mySerial.read();
    if (C<10) Serial.print("0");
    Serial.print(C ,HEX); //Display in HEX
    Serial.print(" ");
    out_flag =1;
  if (out_flag >0) {
    out_flag = 0;
 * The following function is to receive data and judge if it is HEX character. Hex characters
 * include 1,2,3,4,5,6,7,8,9,0,a,b,c,d,e,f,A,B,C,D,E,F
 * Any other characters sent with the command will be ignored.
int SerialReadHexDigit()
  byte c = (byte) Serial.read();
  if (c >= '0' && c <= '9') {
    return c - '0';
  else if (c >= 'a' && c <= 'f') {
    return c - 'a' + 10;
  else if (c >= 'A' && c <= 'F') {
    return c - 'A' + 10;
  else {
    return -1; // getting here is bad: it means the character was invalid
And only appears "Serial number will be displayed here if a card is detected by the module". Nothing more.
I read some topics that SoftwareSerial doesn't work very well on Mega 2560. So I am trying to change to Hardware Serial 1 (RX1: PIN19, TX1: PIN18) and only write Serial number will be displayed here if a card is detected by the module again.
My code now is this:
int comlen =0;
int out_flag =0;
  Serial1.begin(9600);
  delay(10);
  Serial1.write(0x02); //Send the command to read RFID tag, please refer to the manual for more detail.
    if(a>=0){
      CMD[comlen] = a;
      comlen++;
    delay(10);
    int c = Serial1.write( CMD[i]*16 + CMD[i+1]); //Convert Hex Characters in to Hex number, and send it to RFID.
  comlen =0;
  while (Serial1.available()) {
    byte C = Serial1.read();
    Serial.print(" ");
    out_flag =1;
  if (out_flag >0) {
    out_flag = 0;
    return c - '0';
  else {
It is expected to appear something like 8C 9A F5 10
Please, give me some orientation.
Repost after using the Arduino's Auto Format tool (Ctrl + T in the Arduino IDE).
Sorry about that, now is correct.
The pin is: GND - GND
VCC - 5V
RXD - PIN19
TXD - PIN18
I got the solution, the RXD is PIN18 and TXD is PIN19. Now it's working.
