My RFID reader is not being acknowledged by my Arduino in this code:
// Project 45
#define lockPin 7
#define speakerPin 9
#define tx 3
#define rx 2
#define unlockLength 2000
#include <SoftwareSerial.h>
SoftwareSerial rfidReader = SoftwareSerial(rx, tx);
int users = 3;
char* cards[] = { // valid cards
"6F005C6E60",
"3D00251C27",
"3D0029E6BF",
char* names[] = { // cardholder names
"Tom Smith",
"Dick Jones",
"Harry Roberts"
pinMode (lockPin, OUTPUT);
pinMode (speakerPin, OUTPUT);
digitalWrite(lockPin, LOW);
rfidReader.begin(9600);
char cardNum[10]; // array to hold card number
byte cardBytes[6]; // byte version of card number + checksum
int index=0; // current digit
byte byteIn=0; // byte read from RFID
byte lastByte=0; // the last byte read
byte checksum = 0; // checksum result stored here
if (rfidReader.read()==2) { // read the RFID reader
while(index<12) { // 12 digits in unique serial number
byteIn = rfidReader.read(); // store value in byteIn
if ((byteIn==1) || (byteIn==2) || (byteIn==10) || (byteIn==13)) {return;}
// if STX, ETX, CR or LF break
if (index<10) {cardNum[index]=byteIn;} // store first 10 HEX digits only(last 2 are checksum)
// convert ascii hex to integer hex value
if ((byteIn>='0') && (byteIn<='9')) {
byteIn -= '0';
else if ((byteIn>='A') && (byteIn<='F')) {
byteIn = (byteIn+10)-'A';
if ((index & 1) == 1) { // if odd number merge 2 4 bit digits into 8 bit byte
cardBytes[index/2]= (byteIn | (lastByte<<4)); // move the last digit 4 bits left and add new digit
if (index<10) {checksum ^= cardBytes[index/2];} // tot up the checksum value
lastByte=byteIn; // store the last byte read
index++; // increment the index
if (index==12) {cardNum[10] = '\0';} // if we have reached the end of all digits add a null terminator
Serial.println(cardNum); // print the card number
int cardIndex =checkCard(cardNum); // check if card is valid and return index number
if(cardIndex>=0 && (cardBytes[5]==checksum)) { // if card number and checksum are valid
Serial.println("Card Validated");
Serial.print("User: ");
Serial.println(names[cardIndex]); // print the relevant name
unlock(); // unlock the door
else {
Serial.println("Card INVALID");
tone(speakerPin, 250, 250);
delay(250);
tone(speakerPin, 150, 250);
int checkCard(char cardNum[10]) {
for (int x=0; x<=users; x++) { // check all valid cards
if(strcmp(cardNum, cards[x])==0) { // compare with last read card number
return (x); // return index of card number
return (-1); // negative value indicates no match
void unlock() {
tone(speakerPin, 1000, 500);
digitalWrite(lockPin, HIGH);
delay(unlockLength);
Using on a mega, I am POSITIVE that the reader works, and the rx pin works, too. I am at wit's end. Any help appreciated.
-Jelimoore
