Rfid Reader Mrc522
I'm trying to use my rfid reader to play with my card
I first wanted to copy a card to another brand new, but when I use this code :
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN 9 // Configurable, see typical pin layout above
#define SS_PIN 10 // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
byte buffer[18];
byte block;
byte waarde[64][16];
MFRC522::StatusCode status;
MFRC522::MIFARE_Key key;
// Number of known default keys (hard-coded)
// NOTE: Synchronize the NR_KNOWN_KEYS define with the defaultKeys array
#define NR_KNOWN_KEYS 8
// Known keys, see: https://code.google.com/p/mfcuk/wiki/MifareClassicDefaultKeys
byte knownKeys[NR_KNOWN_KEYS][MFRC522::MF_KEY_SIZE] = {
{0xff, 0xff, 0xff, 0xff, 0xff, 0xff}, // FF FF FF FF FF FF = factory default
{0xa0, 0xa1, 0xa2, 0xa3, 0xa4, 0xa5}, // A0 A1 A2 A3 A4 A5
{0xb0, 0xb1, 0xb2, 0xb3, 0xb4, 0xb5}, // B0 B1 B2 B3 B4 B5
{0x4d, 0x3a, 0x99, 0xc3, 0x51, 0xdd}, // 4D 3A 99 C3 51 DD
{0x1a, 0x98, 0x2c, 0x7e, 0x45, 0x9a}, // 1A 98 2C 7E 45 9A
{0xd3, 0xf7, 0xd3, 0xf7, 0xd3, 0xf7}, // D3 F7 D3 F7 D3 F7
{0xaa, 0xbb, 0xcc, 0xdd, 0xee, 0xff}, // AA BB CC DD EE FF
{0x00, 0x00, 0x00, 0x00, 0x00, 0x00} // 00 00 00 00 00 00
char choice;
  • Initialize.
    Serial.begin(9600); // Initialize serial communications with the PC
    while (!Serial); // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
    SPI.begin(); // Init SPI bus
    mfrc522.PCD_Init(); // Init MFRC522 card
    Serial.println(F(“Try the most used default keys to print block 0 to 63 of a MIFARE PICC.”));
    Serial.println(“1.Read card \n2.Write to card \n3.Copy the data.”);
for (byte i = 0; i < 6; i++) {
key.keyByte = 0xFF;
    //Via seriele monitor de bytes uitlezen in hexadecimaal
    void dump_byte_array(byte *buffer, byte bufferSize) {
  • for (byte i = 0; i < bufferSize; i++) {*
    _ Serial.print(buffer < 0x10 ? " 0" : " ");_
    _ Serial.print(buffer*, HEX);
    //Via seriele monitor de bytes uitlezen in ASCI*
    void dump_byte_array1(byte *buffer, byte bufferSize) {
    * for (byte i = 0; i < bufferSize; i++) {
    Serial.write(buffer);
    * Try using the PICC (the tag/card) with the given key to access block 0 to 63.
    * On success, it will show the key details, and dump the block data on Serial.
    @return true when the given key worked, false otherwise.
    boolean try_key(MFRC522::MIFARE_Key *key)
    boolean result = false;*_
* for(byte block = 0; block < 64; block++){*
* // Serial.println(F(“Authenticating using key A…”));*
* status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, block, key, &(mfrc522.uid));
if (status != MFRC522::STATUS_OK) {
Serial.print(F("PCD_Authenticate() failed: "));
_ Serial.println(mfrc522.GetStatusCodeName(status));
return false;
// Read block*
* byte byteCount = sizeof(buffer);_
status = mfrc522.MIFARE_Read(block, buffer, &byteCount);
Serial.print(F("MIFARE_Read() failed: "));
else {
// Successful read*
* result = true;
Serial.print(F(“Success with key:”));
dump_byte_array((*key).keyByte, MFRC522::MF_KEY_SIZE);
Serial.println();*_
* // Dump block data*
* Serial.print(F(“Block “)); Serial.print(block); Serial.print(F(”:”));*
* dump_byte_array1(buffer, 16); //omzetten van hex naar ASCI*
* Serial.println();*
* for (int p = 0; p < 16; p++) //De 16 bits uit de block uitlezen*
* waarde [block][p] = buffer[p];*
* Serial.print(waarde[block][p]);*
* Serial.print(" ");*
* Serial.println(“1.Read card \n2.Write to card \n3.Copy the data.”);*
* mfrc522.PICC_HaltA(); // Halt PICC*
* mfrc522.PCD_StopCrypto1(); // Stop encryption on PCD*
* return result;*
* start();*
* Main loop.
* start();*
void start(){
* choice = Serial.read();*
* if(choice == ‘1’)*
* Serial.println(“Read the card”);*
* keuze1();*
* else if(choice == ‘2’)*
* Serial.println(“See what is in the variables”);*
* keuze2();*
* else if(choice == ‘3’)*
* Serial.println(“Copying the data on to the new card”);*
* keuze3();*
void keuze2(){ //Test waardes in blokken
* for(block = 4; block <= 62; block++){*
* if(block == 7 || block == 11 || block == 15 || block == 19 || block == 23 || block == 27 || block == 31 || block == 35 || block == 39 || block == 43 || block == 47 || block == 51 || block == 55 || block == 59){*
* block ++;*
* Serial.print(F("Writing data into block "));*
* Serial.print(block);*
* Serial.println("\n");*
* for(int j = 0; j < 16; j++){*
* Serial.print(waarde[block][j]);*
* start();*
void keuze3(){ //Copy the data in the new card
Serial.println(“Insert new card…”);
* // Look for new cards*
* if ( ! mfrc522.PICC_IsNewCardPresent())
_ return;
// Select one of the cards*
* if ( ! mfrc522.PICC_ReadCardSerial())*
* return;
// Show some details of the PICC (that is: the tag/card)
Serial.print(F(“Card UID:”));_
dump_byte_array(mfrc522.uid.uidByte, mfrc522.uid.size);
_ Serial.println();
Serial.print(F("PICC type: "));_
MFRC522::PICC_Type piccType = mfrc522.PICC_GetType(mfrc522.uid.sak);
Serial.println(mfrc522.PICC_GetTypeName(piccType));*
* // Try the known default keys*
/MFRC522::MIFARE_Key key;
for (byte k = 0; k < NR_KNOWN_KEYS; k++) {
// Copy the known key into the MIFARE_Key structure*
* for (byte i = 0; i < MFRC522::MF_KEY_SIZE; i++) {
key.keyByte _= knownKeys[k];
* for (byte i = 0; i < 6; i++) {
key.keyByte = 0xFF;
for(int i = 4; i <= 62; i++){ //De blocken 4 tot 62 kopieren, behalve al deze onderstaande blocken (omdat deze de authenticatie blokken zijn)
if(i == 7 || i == 11 || i == 15 || i == 19 || i == 23 || i == 27 || i == 31 || i == 35 || i == 39 || i == 43 || i == 47 || i == 51 || i == 55 || i == 59){
i++;
block = i;*_
* // Authenticate using key A*
* Serial.println(F(“Authenticating using key A…”));*
* status = (MFRC522::StatusCode) mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, block, &key, &(mfrc522.uid));
return;
}*_
* // Authenticate using key B*
* Serial.println(F(“Authenticating again using key B…”));*
* status = (MFRC522::StatusCode) mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_B, block, &key, &(mfrc522.uid));
return;
}*_
[/code]
I get some error about PCD_Authenticate ()
So I can only read block 1, Block 2, and Block 3 of my card, after I get that error
What is that ?
Thanks you
Best regards,
Tib
(deleted)
