RFID Reader RDM880-T-A seedstudio: How to read Mifare Data Block?
Hi.
after reading the RFIDs ID sucessfully for some time with the Seedstudio 13.56Mhz Module, I wanted to read out data blocks from the RFID chip now.
based on the protocol’s manual (page 20) you can send out data blocks by sending:
Send Data:AA 00 0A 20 01 01 10 ff ff ff ff ff ff 3A BB(Read the data from the 16th block to 19th
block )
where ff ff ff ff ff ff is supposed to be “the key”.
if I modify the seedstudios example code to this:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3);
char txrxbuffer[255];
char get_readID[] = { 0xAA , 0x00, 0x0A, 0x20, 0x01, 0x01, 0x10, 0xFF, 0xFF,0xFF, 0xFF,0xFF, 0xFF, 0x3A, 0xBB };
Serial.println("Hit Enter to read the RFID number");
mySerial.begin(9600);
void loop() // run over and over
int counter = 0;
if (mySerial.available())
  Serial.print(mySerial.read(),HEX);
if (Serial.available()){
    Serial.read();
    Serial.println(">");
    for (counter =0 ; counter < 15 ; counter++){
      mySerial.write(get_readID[counter]);
the serial only returns two empty lines
I think its because i just left the key like in the protocols manual for I could not make out what this key identifies exactly and how to get the proper key.
Maybe its something else in the command or both?
I would appreciate any kind of suggestion.
thx!
