Hello,
I'm using an Arduino in order to read some RFID tags and open a door if the tag is enabled. The program is really simple: Arduino reads the tag, then asks the main server what to do with an http GET. The answer is the number of "credits" that the tag has, so if it's greater than 0 then Arduino opens the door.
The problem is that sometimes (quite often) the server receives a request with a wrong tag, that could be shorter or longer than usual. This for example is (taken from the Apache logs) a "right2 request:
10.3.8.250 - - [31/Mar/2016:18:46:51 +0200] "GET /door/index.php?ID=54004E25506F" 200 24 "-" "-"
In this case the tag is too short:
10.3.8.250 - - [31/Mar/2016:18:46:35 +0200] "GET /door/index.php?ID=54" 200 21 "-" "-"
Sometimes is too long:
10.3.8.250 - - [31/Mar/2016:18:46:42 +0200] "GET /door/index.php?ID=54004E25506F54004E25506F\xfd\x02\x80" 200 21 "-" "-"
What's going on?
This is the code:
#include <SPI.h> // needed for Arduino versions later than 0018
#include <Ethernet2.h>
#include <TextFinder.h>
byte mac[] = { 0x90, 0xA2, 0xDA, 0x10, 0x21, 0x8c };
byte ip[] = { 10, 3, 8, 250 };
byte gateway[] = { 10, 3 , 8, 1 };
byte subnet[] = { 255, 255, 255, 0 };
const IPAddress server(10, 3, 8, 254);
long lastRequestTime = 0;
float answer;
int buttonState = 0;
EthernetClient client;
String Request;
int RFIDResetPin = 2;
int DoorPin = 8;
int ExitButtonPin = 9;
/* SETUP */
pinMode(ExitButtonPin, INPUT);
pinMode(RFIDResetPin, OUTPUT);
pinMode(DoorPin, OUTPUT);
digitalWrite(RFIDResetPin, HIGH);
digitalWrite(DoorPin, HIGH);
Ethernet.begin(mac, ip, subnet, gateway);
delay(2000);
/* LOOP */
answer = 0;
buttonState = digitalRead(ExitButtonPin);
if (buttonState == HIGH) { //open the door if someone needs to exit
digitalWrite(DoorPin, LOW);
delay(5000);
else {
char tagString[13] = "";
int index = 0;
boolean reading = false;
while (Serial.available()) {
int readByte = Serial.read(); //read next available byte
if (readByte == 2) reading = true; //begining of tag
if (readByte == 3) reading = false; //end of tag
if (reading && readByte != 2 && readByte != 10 && readByte != 13) {
tagString[index] = readByte; //store the tag
index ++;
checkTag(tagString); //Check if it is a match
clearTag(tagString); //Clear the char of all value
resetReader(); //Reset the RFID reader
void checkTag(char tag[]) {
if (strlen(tag) == 0) return; //empty, no need to contunue
if (strlen(tag) > 0) {
if (client.connected()) {
client.stop();
if (client.connect(server, 80)) {
Request = "GET /door/index.php?ID=";
String strtag(tag);
Request += strtag;
Request += "\r\n HTTP/1.1\r\nHost: arduino.server.local\r\n\r\n";
client.println(Request);
client.println();
lastRequestTime = millis(); // note the time of this connect attempt:
if (client.connected() ) { // if you're connected to the server:
if (client.available()) { // if there are bytes available from the server
TextFinder response(client); // make an instance of TextFinder to search the response
if (response.find("<answer>")) { // see if the response from the server contains <answer>
answer = response.getFloat(); // get the answer
client.stop(); // stop the client, and close the connection
answer = 0;
client.flush();
if (!client.connected()) {
client.stop();
if (answer >= 1) {
delay(5000);
void resetReader() {
digitalWrite(RFIDResetPin, LOW);
delay(150);
void clearTag(char one[]) {
for (int i = 0; i < strlen(one); i++) {
one[i] = 0;
Thanks!
Matteo
