I'm doing a project and I need to use RFID and micro sd card reader together on arduino mega. So I did the connections and use SPI connections on the same pins. For example, RFID's SCK and SD card reader's SCK to 52 pin. I use the correct SS pins to but it does not work. RFID some times works after I put 330 ohm resistor between sd card's miso pin and mega's miso pin but after scanning some card's it starts not working. My project is due 1 week and it is the last thing i need to do.
Code:
#include <SPI.h>
#include <TMRpcm.h>
#include <pcmConfig.h>
#include <pcmRF.h>
#include <SD.h>
#include <MFRC522.h>
#include <LiquidCrystalTr.h>
#include <Keypad.h>
#include <SoftwareSerial.h>
SoftwareSerial mySerial(11, 10);
//Speacker and Micro SD Card Reader
#define sdpin 13
TMRpcm tmrpcm;
// Creating RFID
#define RST_PIN 8
#define SS_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN);
MFRC522::MIFARE_Key key;
//KEYPAD
const byte ROWS = 4;
const byte COLS = 4;
char hexaKeys[ROWS][COLS] = {
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
byte rowPins[ROWS] = {37, 36, 35, 34};
byte colPins[COLS] = {33, 32, 31, 30};
Keypad customKeypad = Keypad(makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
bool captureInput = false;
String capturedInput = "";
//LCD
const int rs = 6, en =7, d4 =2, d5 = 3, d6=4, d7=5;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
int wb = 11;
int wa = 0;
//Students and Teacher
byte cardID[4];
int ID[4];
int slot = 0;
byte Tcard[4] = {0xc3, 0xc1, 0x90, 0xa5};
char Tname[] = "Mahmut Ağan";
char Tid[] = "6546";
byte card[7][4] = {{0x63, 0x96, 0x15, 0x34}, {0x63, 0x95, 0xa1, 0x34}, {0xa1, 0x05, 0xd3, 0x1d}, {0x91, 0xaa, 0x92, 0x1d}, {0x23, 0x5D, 0x18, 0x16}, {0x93, 0x75, 0x27, 0x16}, {0x50, 0x15, 0xCA, 0x80}};
char name[7][30] = {" Charlotte Taylor-Smith ", " Elizabeth Woolridge Grant ", " Kağan Akgün", " Emre Göğer", "Jasper Fahey", "Murathan Hatay", "Emirhan Çoban"};
char id[7][4] = {"7849", "5925", "2858", "9298", "9132", "2201", "4234"};
bool att[7] = {0, 0, 0, 0, 0, 0, 0};
bool dis[7] = {1, 0, 0, 0, 1, 0, 1};
bool te = 0;
//Fun Card
byte fun[4] = {0xe3, 0x72, 0x13, 0xad};
int timer = 0, ftimer = 0, ntimer = 0, stimer = 0;
char * start = " Scan card or Press 'A' ";
char * attendance = " Attendance has already been taken ";
int iLineNumber = 1;
int LineNumber = 0; // Line number to show your string (Either 0 or 1)
int iCursor = 0;
int place;
String sending;
mySerial.begin(9600);
SPI.begin();
mfrc522.PCD_Init();
lcd.begin(16, 2);
//Speaker and sd
tmrpcm.speakerPin = 12;
while(!SD.begin(sdpin)){
lcd.print("problem");
lcd.clear();
tmrpcm.setVolume(1);
if(mySerial.available() > 0){
char sdata[10];
mySerial.readBytesUntil('\n', sdata, 10);
Serial.println(sdata);
int rdata = atoi(sdata);
while(rdata == 1){
lcd.setCursor(3, 0);
lcd.print("Connection");
lcd.setCursor(5, 1);
lcd.print("Error");
Serial.println(rdata);
if(rdata == 0){
lcd.clear();
for(int i = 0; i < 4; i++){
ID[i] = 0;
lcd.setCursor(4,0);
lcd.print("EEE1002");
lcd.setCursor(0,1);
Scroll(start);
stimer = 0;
while(stimer < 8){
delay(50);
stimer++;
char key = customKeypad.getKey();
//Starts the ID taking from keypad if 'A' is pushed
if(key){
if(key == 'A'){
lcd.clear();
lcd.print("Please enter ID:");
while(1){
if(key){
//Takes the written ID
if(slot<=3 && slot>=0 && key != 'A' && key != 'B' && key != 'C' && key != 'D' && key != '#' && key != '*'){
ID[slot]= key;
lcd.setCursor(slot,1);
lcd.print(key);
slot++;
//Deletes one character while writing the ID
if(key == 'C'){
if(slot>0&&slot<=4){
slot=slot-1;
lcd.print(" ");
//Cancels the operation
if(key == 'D'){
slot=0;
//Accepts the written ID
if(key == 'B'){
tmrpcm.play("abcd.wav");
lcd.clear();
Wait();
lcd.clear();
//ID Part
if(ID[0] == Tid[0] && ID[1] == Tid[1] && ID[2] == Tid[2] && ID[3] == Tid[3] && te == 0 && ftimer == 0){
tmrpcm.play("efgh.wav");
te=1;
mySerial.println("-1");
if(strlen(Tname) > 16){
while(ntimer < 30){
Scroll(Tname);
delay(280);
ntimer++;
}else{
place = floor((16 - strlen(Tname))/2);
lcd.setCursor(place,0);
lcd.print(Tname);
ntimer = 0;
iCursor = 0;
while(ntimer < 30){
Scroll(" Attendance taking has been started ");
delay(300);
ntimer++;
lcd.clear();
timer = 0;
ntimer = 0;
iCursor = 0;
lcd.clear();
slot=0;
return;
else if(ID[0] == Tid[0] && ID[1] == Tid[1] && ID[2] == Tid[2] && ID[3] == Tid[3] && te == 1){
tmrpcm.play("defg.wav");
te=0;
for(int b = 0; b < 7; b++){
att[b] = 0;
while(ntimer < 30){
Scroll(Tname);
delay(280);
ntimer++;
}else{
lcd.print(Tname);
ntimer = 0;
iCursor = 0;
while(ntimer < 30){
Scroll(" Attendance taking has been over ");
delay(280);
ntimer++;
ntimer = 0;
lcd.clear();
slot=0;
timer = 0;
iCursor = 0;
return;
else if(ID[0] == Tid[0] && ID[1] == Tid[1] && ID[2] == Tid[2] && ID[3] == Tid[3] && ftimer > 0){
ntimer = 0;
iCursor = 0;
while(ntimer < 30){
Scroll1(" Attendance taking has been over ");
delay(280);
ntimer++;
lcd.clear();
slot=0;
timer = 0;
iCursor = 0;
return;
for(int i = 0; i < 7; i++){
if(ID[0] == id[i][0] && ID[1] == id[i][1] && ID[2] == id[i][2] && ID[3] == id[i][3] && te == 1 && att[i] == 0){ //Takes the
if(dis[i] == 1){
tmrpcm.play("ghij.wav");
int b = i+1;
Serial.println(b);
iCursor = 0;
lcd.setCursor(4, 0);
lcd.print("Welcome");
if(strlen(name[i]) > 16){
while(ntimer < 30){
Scroll(name[i]);
delay(280);
ntimer++;
}else{
place = floor((16 - strlen(name[i]))/2);
lcd.setCursor(place,1);
lcd.print(name[i]);
delay(4000);
lcd.clear();
att[i] = 1;
timer = 0;
ntimer = 0;
return;
else if(ID[0] == id[i][0] && ID[1] == id[i][1] && ID[2] == id[i][2] && ID[3] == id[i][3] && te == 1 && att[i] == 1){
if(dis[i] == 1){
tmrpcm.play("fghi.wav");
iCursor = 0;
while(ntimer < 30){
Scroll1(attendance);
delay(280);
ntimer++;
lcd.clear();
timer = 0;
ntimer = 0;
iCursor = 0;
return;
return;
else if(ID[0] == id[i][0] && ID[1] == id[i][1] && ID[2] == id[i][2] && ID[3] == id[i][3] && te == 0){
if(dis[i] == 1){
tmrpcm.play("cdef.wav");
iCursor = 0;
lcd.setCursor(0,0);
lcd.print("Wait the Teacher");
while(ntimer < 30){
Scroll(" Attendance taking has not been started ");
delay(280);
ntimer++;
ntimer = 0;
iCursor = 0;
lcd.clear();
slot=0;
return;
//ID is not in the class list
iCursor = 0;
tmrpcm.play("bcde.wav");
tmrpcm.play("hijk.wav");
while(ntimer < 35){
Scroll1(" You are not a participant in this course ");
delay(280);
ntimer++;
ntimer = 0;
iCursor = 0;
lcd.clear();
slot=0;
return;
if ( ! mfrc522.PICC_IsNewCardPresent()) {
if(te == 1){
timer++;
delay(50);//0.05 seconds
if(timer == 8000){// 8000 about 11 minutes
ftimer = 1;
timer = 0;
te = 0;
att[b] = 0;
lcd.clear();
ntimer = 0;
iCursor = 0;
while(ntimer < 30){
delay(280);
ntimer++;
ntimer = 0;
iCursor = 0;
lcd.clear();
if(ftimer > 0){
ftimer++;
delay(50);
if(ftimer == 8000){ // 16000 about 22 minutes
ftimer = 0;
if ( ! mfrc522.PICC_ReadCardSerial()) {
lcd.clear();
return;
lcd.clear();
Wait();
lcd.clear();
//Get the UID of the scaned card
for (byte i = 0; i < mfrc522.uid.size; i++) {
cardID[i]=mfrc522.uid.uidByte[i];
//Fun Card
if(cardID[0] == fun[0] && cardID[1] == fun[1] && cardID[2] == fun[2] && cardID[3] == fun[3]){
lcd.print("how do you have");
lcd.setCursor(0,1);
lcd.print("this card");
delay(3000);
lcd.clear();
return;
// CARD
if(cardID[0] == Tcard[0] && cardID[1] == Tcard[1] && cardID[2] == Tcard[2] && cardID[3] == Tcard[3] && te == 0 && ftimer == 0){
te=1;
char sendData[] = "-1";
mySerial.println(sendData);
while(ntimer < 30){
Scroll(Tname);
delay(280);
ntimer++;
}else{
lcd.print(Tname);
ntimer = 0;
iCursor = 0;
while(ntimer < 30){
delay(300);
ntimer++;
lcd.clear();
timer = 0;
ntimer = 0;
iCursor = 0;
lcd.clear();
slot=0;
return;
else if(cardID[0] == Tcard[0] && cardID[1] == Tcard[1] && cardID[2] == Tcard[2] && cardID[3] == Tcard[3] && te == 1){
te=0;
att[b] = 0;
while(ntimer < 30){
Scroll(Tname);
delay(280);
ntimer++;
}else{
lcd.print(Tname);
ntimer = 0;
iCursor = 0;
while(ntimer < 30){
delay(280);
ntimer++;
lcd.clear();
slot=0;
timer = 0;
iCursor = 0;
return;
else if(cardID[0] == Tcard[0] && cardID[1] == Tcard[1] && cardID[2] == Tcard[2] && cardID[3] == Tcard[3] && ftimer > 1){
ntimer = 0;
iCursor = 0;
while(ntimer < 30){
delay(280);
ntimer++;
lcd.clear();
slot=0;
timer = 0;
iCursor = 0;
return;
if(cardID[0] == card[i][0] && cardID[1] == card[i][1] && cardID[2] == card[i][2] && cardID[3] == card[i][3] && te == 1 && att[i] == 0){
int b = i+1;
char sendData[10];
sprintf(sendData, "%d", b);
if(dis[i] == 1){
iCursor = 0;
while(ntimer < 30){
Scroll(name[i]);
delay(280);
ntimer++;
}else{
lcd.print(name[i]);
delay(4000);
lcd.clear();
att[i] = 1;
timer = 0;
ntimer = 0;
iCursor = 0;
return;
else if(cardID[0] == card[i][0] && cardID[1] == card[i][1] && cardID[2] == card[i][2] && cardID[3] == card[i][3] && te == 1 && att[i] == 1){
if(dis[i] == 1){
iCursor = 0;
while(ntimer < 30){
delay(280);
ntimer++;
lcd.clear();
timer = 0;
ntimer = 0;
iCursor = 0;
return;
else if(cardID[0] == card[i][0] && cardID[1] == card[i][1] && cardID[2] == card[i][2] && cardID[3] == card[i][3] && te == 0){ //Does not take attendance because the lesson is deactive
if(dis[i] == 1){
iCursor = 0;
lcd.setCursor(0,0);
while(ntimer < 30){
delay(280);
ntimer++;
ntimer = 0;
iCursor = 0;
lcd.clear();
slot=0;
return;
//Card is not in the class list
iCursor = 0;
while(ntimer < 35){
delay(280);
ntimer++;
ntimer = 0;
iCursor = 0;
lcd.clear();
slot=0;
void Scroll(const char * text) {
int iLenOfLargeText = strlen(text); // Calculate lenght of string.
if (iCursor == (iLenOfLargeText - 1) ) // Reset variable for rollover effect.
iCursor = 0;
//lcd.clear();
lcd.setCursor(0,iLineNumber);
if(iCursor < iLenOfLargeText - 16) // This loop exicuted for normal 16 characters.
for (int iChar = iCursor; iChar < iCursor + 16 ; iChar++)
lcd.print(text[iChar]);
for (int iChar = iCursor; iChar < (iLenOfLargeText - 1) ; iChar++) // This code takes care of printing charecters of current string.
for (int iChar = 0; iChar <= 16 - (iLenOfLargeText - iCursor); iChar++) // Reamining charecter will be printed by this loop.
iCursor++;
void Scroll1(const char * text) {
iCursor = 0;
//lcd.clear();
lcd.setCursor(0,LineNumber);
iCursor++;
void Wait(){
lcd.print("Please Wait");
while(wa <9){
if(wb % 3 == 2){
lcd.setCursor(12, 0);
lcd.print(" ");
lcd.setCursor(11, 0);
lcd.print(".");
else if(wb % 3 == 0){
lcd.print(" ");
lcd.setCursor(13, 0);
lcd.print(" ");
lcd.print(".");
else if(wb % 3 == 1){
lcd.print(" ");
lcd.print(".");
delay(300);
wa++;
wb++;
wa = 0;
wb = 11;
