RFID Reading from Setup While loop doesn't work.
Here's the code I'm copying from.
#include <SPI.h>      //include the SPI bus library
#include <MFRC522.h>  //include the RFID reader library
#define SS_PIN 10  //slave select pin
#define RST_PIN 9  //reset pin
MFRC522 mfrc522(SS_PIN, RST_PIN);  // instatiate a MFRC522 reader object.
MFRC522::MIFARE_Key key;          //create a MIFARE_Key struct named 'key', which will hold the card information
//this is the block number we will write into and then read.
int block=2;
//This array is used for reading out a block.
byte readbackblock[18];
    Serial.begin(9600);        // Initialize serial communications with the PC
    SPI.begin();               // Init SPI bus
    mfrc522.PCD_Init();        // Init MFRC522 card (in case you wonder what PCD means: proximity coupling device)
    Serial.println("Scan a MIFARE Classic card");
  // Prepare the security key for the read and write functions.
  for (byte i = 0; i < 6; i++) {
    key.keyByte[i] = 0xFF;  //keyByte is defined in the "MIFARE_Key" 'struct' definition in the .h file of the library
  // Look for new cards
  if ( ! mfrc522.PICC_IsNewCardPresent()) {
    return;
  // Select one of the cards
  if ( ! mfrc522.PICC_ReadCardSerial())
    return;
    Serial.println("card selected");
   //read the block back
   readBlock(block, readbackblock);
   Serial.print("read block: ");
   for (int j=0 ; j<16 ; j++)
     Serial.write (readbackblock[j]);
   Serial.println("");
//Read specific block
int readBlock(int blockNumber, byte arrayAddress[])
  int largestModulo4Number=blockNumber/4*4;
  int trailerBlock=largestModulo4Number+3;//determine trailer block for the sector
  //authentication of the desired block for access
  byte status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, trailerBlock, &key, &(mfrc522.uid));
  if (status != MFRC522::STATUS_OK) {
         Serial.print("PCD_Authenticate() failed (read): ");
         Serial.println(mfrc522.GetStatusCodeName(status));
         return 3;//return "3" as error message
//reading a block
byte buffersize = 18;//we need to define a variable with the read buffer size, since the MIFARE_Read method below needs a pointer to the variable that contains the size...
status = mfrc522.MIFARE_Read(blockNumber, arrayAddress, &buffersize);//&buffersize is a pointer to the buffersize variable; MIFARE_Read requires a pointer instead of just a number
          Serial.print("MIFARE_read() failed: ");
          return 4;//return "4" as error message
  Serial.println("block was read");
This works. But if I move it to a while loop in the setup if fails. I have no idea why or how to fix it!
