RFID scanner with Sensors
Hi I am designing a system in which a RFID scanner scans a block and then turns on the corresponding sensor within a loop. So far I coded this:
// RFID reader for Arduino
// Wiring version by BARRAGAN http://people.interaction-ivrea.it/h.barragan
// Modified for Arudino by djmatic
int val = 0;
char code[10];
int bytesread = 0;
Serial.begin(2400); // RFID reader SOUT pin connected to Serial RX pin at 2400bps
pinMode(2,OUTPUT); // Set digital pin 2 as OUTPUT to connect it to the RFID /ENABLE pin
digitalWrite(2, LOW); // Activate the RFID reader
if(Serial.available() > 0) { // if data available from reader
if((val = Serial.read()) == 10) { // check for header
bytesread = 0;
while(bytesread<10) { // read 10 digit code
if( Serial.available() > 0) {
val = Serial.read();
if((val == 10)||(val == 13)) { // if header or stop bytes before the 10 digit reading
break; // stop reading
code[bytesread] = val; // add the digit
bytesread++; // ready to read next digit
if(bytesread == 10) { // if 10 digit read is complete
Serial.print("TAG code is: "); // possibly a good TAG
Serial.println(code); // print the TAG code
bytesread = 0;
digitalWrite(2, HIGH); // deactivate the RFID reader for a moment so it will not flood
delay(2000); // wait for a bit
which prints out the serial number of each block. I now want to embed an if loop to say if its a certain block then the certain sensor turns on. Any help would be greatly appreciated. Thank you
Sorry I have no idea what you want to do.
What is a block? How is the RFID scanning it?
What sensor?
