Both parts will work separately(tested and working) but I can't seem to get the right code going. Its based on (http://www.seeedstudio.com/wiki/Grove_-_125KHz_RFID_Reader) which will give me the RFID tag number in the Serial monitor but I can't seem to save it to the SD card.
#include <SoftwareSerial.h>
#include <SD.h>
#include <SPI.h>
SoftwareSerial SoftSerial(2, 3);
unsigned char buffer[64]; // buffer array for data receive over serial port
int count=0;
File EBBtags;
// counter for buffer array
SoftSerial.begin(9600); // the SoftSerial baud rate
// the Serial port of Arduino baud rate.
if (SoftSerial.available()) // if date is coming from software serial port ==> data is coming from SoftSerial shield
while(SoftSerial.available()) // reading data into char array
buffer[count++]=SoftSerial.read(); // writing data into array
if(count == 64)break;
EBBtags = SD.open("Bandicoot.txt", FILE_WRITE);
Serial.write(buffer,count);
EBBtags.write(buffer,count);
EBBtags.close(); // if no data transmission ends, write buffer to hardware serial port
clearBufferArray(); // call clearBufferArray function to clear the stored data from the array
count = 0; // set counter of while loop to zero
if (Serial.available()) // if data is available on hardware serial port ==> data is coming from PC or notebook
SoftSerial.write(Serial.read()); // write it to the SoftSerial shield
void clearBufferArray() // function to clear buffer array
for (int i=0; i<count;i++)
{ buffer[i]=NULL;} // clear all index of array with command NULL
I've tried adding this, which i've understood is how you open,write and close a file.
EBBtags.println(FEW DIFFERENT COMBINATIONS IN HERE);
EBBtags.close();
HELP? What am I doing wrong? Everything? probably.
Can you post a picture of the SoftSerial that you attached to the Arduino?
Wouldn't rfid make a more meaningful name? That way, you COULD post a picture of the RFID reader that you attached to the Arduino.
Just in case some function blows the first STOP sign, put up some more. Maybe the function will get the hint by the 15th or 20th STOP sign. WRONG!
No, I REALLY need to see a picture of this SoftSerial shield!
Thanks nick, i've had a read over other that link and yeah the serial.write was a hail mary.
How would you go about saving the RFID tag to an SD card?
Fair enough it probably would Paul, but as i mentioned above that part of the code was copied from a website and works just fine. Its getting from there to an SD card that I need help with.
Both show how to gather the RFID code from a card before deciding what to do with it. First hint it, you don't expect the entire card data to arrive at once. You wait for a terminator, or the correct number of bytes, depending on the type of reader.
Did you managed to solve your problem? I can suggest a solution
I store my RFID tags' UID information on SD card as filenames. It's simplest solution i can guess of and using this way in my RFID project. Of course you are limited with 6 bytes due to 8.3 filename limitation, also you won't need to search in text files for information simple SD.exist() function will be enough. If you are good with 6 bytes, you can create files as "XXXXXXXX.XXX" where Xs will be the data of your choice.
char filename[] = "XXXXXXXX.DAT"; // 4 bytes enough in my case.
char extension[] = "DAT";
byte readCard[4];
When RFID host reads a Tag program stores it's 4 byte UID information on readCard variable
Need to convert data to char
void getFilename() { // We will store UIDs as files on SD card
sprintf(filename, "%02x%02x%02x%02x.%s", readCard[0], readCard[1], // Convert readCard data to char and append extension
readCard[2], readCard[3], extension);
Finally create a file on SD card
void writeID () {
getFilename(); // You should call it wherever need
File filewrite = SD.open(filename, FILE_WRITE);
filewrite.close();
if (SD.exists(filename)) {
Serial.println(F("Succesfully added ID record"));
else {
Serial.println(F("Failed to add record"));
In my case program checks if scanned tag have its own file on SD card and decides what to do next, you can check my project here
