RFID Servo Jitter
I have an Parallax RFID reader and a HI Tec HS-422 servo motor connected to my Arduino Uno R2. The Servo is being powered externally, and I have the 5v for the RFID connected to the Arduino.
When ever I read a tag on the RFID reader, the servo starts to become jittery if I'm use the write(); function to control the servo.
Anyone have any ideas what the problem is? I tried using some pulse width stuff but that didn't seem to many any difference.
below is the code
RFID SOUT <---> Arduino Digital Pin 5
RFID ENABLE <---> Arduino Digital Pin 2
#include <SoftwareSerial.h>
#include <Servo.h>
//Parallax RFID Reader
#define RFIDEnablePin 2 //Pin that enables reading. Set as OUTPUT and LOW to read an RFID tag
#define RFIDSerialRate 2400 //Parallax RFID Reader Serial Port Speed
#define servoPin 4 //servo pin
#define minPulse 500 //minimum servo position (originally 500)
#define maxPulse 2200 //max servo position (originally 2200)
int refreshTime = 20;
//arduino will calculate these values
int pulseWidth;
long lastPulse = 0;
//Using SoftwareSerial Library to locate the serial pins off the default set
//This allows the Arduino to be updated via USB with no conflict
#define RxPin 8 //Pin to read data from Reader
#define TxPin 9 //Pin to write data to the Reader NOTE: The reader doesn't get written to, don't connect this line.
SoftwareSerial RFIDReader(RxPin,TxPin);
boolean balanced =  true;
int myVal = 0;
int pulse, switchVal;
Servo myservo;
#define TOGGLE_LED_STATE_ON 't'
#define TOGGLE_LED_STATE_OFF 'o'
String RFIDTAG=""; //Holds the RFID Code read from a tag
String DisplayTAG = ""; //Holds the last displayed RFID Tag
int firstSensor = 0;
int secondSensor = 0;
int trackNum = 0;
int inByte = 0;
char val;
int ledPin = 13;
int sensorVal = 0;
int servoPos = 0;
  // RFID reader SOUT pin connected to Serial RX pin at 2400bps
  RFIDReader.begin(RFIDSerialRate);
  // Set Enable pin as OUTPUT to connect it to the RFID /ENABLE pin
  pinMode(RFIDEnablePin,OUTPUT);
  // Activate the RFID reader
  // Setting the RFIDEnablePin HIGH will deactivate the reader
  // which could be usefull if you wanted to save battery life for
  // example.
  digitalWrite(RFIDEnablePin, LOW);
  Serial.begin(9600);           // set up Serial library at 9600 bps
  //Serial.println("Hello world --!");  // prints hello with ending line break
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, LOW);
  myservo.attach(4);
  if(RFIDReader.available() > 0) // If data available from reader
    ReadSerial(RFIDTAG);  //Read the tag number from the reader. Should return a 10 digit serial number
  //This only displays a tag once, unless another tag is scanned
  if(DisplayTAG!=RFIDTAG)
    DisplayTAG=RFIDTAG;
    //Serial.println(RFIDTAG);
  if(RFIDTAG == "3600095756"){
    trackNum = 1;
  if(RFIDTAG == "190035D511"){
    trackNum = 2;
  if(RFIDTAG == "190035E473"){
    trackNum = 3;
  if(RFIDTAG == "17007EFC59"){
    trackNum = 4;
  if(RFIDTAG == "190035E3D2"){
    trackNum = 5;
  sensorVal ++;
  Serial.print(trackNum);
  Serial.print(",");
  Serial.println(sensorVal);
  if(Serial.available()){
    val = Serial.read();
    if(val == TOGGLE_LED_STATE_ON){
      digitalWrite(ledPin, HIGH);
      myservo.write(90);
    if(val == TOGGLE_LED_STATE_OFF){
      myservo.write(0);
void ReadSerial(String &ReadTagString)
  int bytesread = 0;
  int  val = 0;
  char code[10];
  String TagCode="";
  if(RFIDReader.available() > 0) {          // If data available from reader
    if((val = RFIDReader.read()) == 10) {   // Check for header
      bytesread = 0;
      while(bytesread<10) {                 // Read 10 digit code
        if( RFIDReader.available() > 0) {
          val = RFIDReader.read();
          if((val == 10)||(val == 13)) {   // If header or stop bytes before the 10 digit reading
            break;                         // Stop reading
          code[bytesread] = val;           // Add the digit
          bytesread++;                     // Ready to read next digit
      if(bytesread == 10) {                // If 10 digit read is complete
        for(int x=0;x<10;x++)              //Copy the Chars to a String
          TagCode += code[x];
        ReadTagString = TagCode;          //Update the caller
        while(RFIDReader.available() > 0) //Burn off any characters still in the buffer
          RFIDReader.read();
      bytesread = 0;
      TagCode="";
