I'm making an RFID music player. One of the player's functions is to turn the LED lights in my room a different color depending on what's being played. I use WLED API to send a POST request to the lights in my room. This works, and the lights change color. However, the RFID module stops detecting new cards after that. I have made sure that the program is still looping, I have no clue what's going on here. I have tried delays and no luck. Any help is greatly appreciated. Here is my code and PIN setup for both the RFID module and SD card module
- RST/Reset RST 21
- SPI SS SDA(SS) 5/15
- SPI MOSI MOSI 23
- SPI MISO MISO 19
- SPI SCK SCK 18
#include <SPI.h>
#include <MFRC522.h>
#include <SD.h>
#include "AudioGeneratorWAV.h"
#include "AudioOutputSerialWAV.h"
#include "AudioFileSourceSD.h"
#include <WiFi.h>
#include <HTTPClient.h>
const char* ssid = "MY SSID";
const char* password = "MY PASSWORD";
const char* serverName = "SERVER NAME";
AudioGeneratorWAV *mp3; //change to MP3 for actual
AudioFileSourceSD *file;
AudioOutputSerialWAV *out;//change to i2s
#define RFID_SS_PIN 5
#define RST_PIN 21
#define SD_SS_PIN 15
byte current_card[4];
byte current_song = 0;
byte playing = 0;
String ext = ".wav";
MFRC522 rfid(RFID_SS_PIN, RST_PIN); // Instance of the class
WiFi.begin(ssid, password);
Serial.println("Connecting");
while(WiFi.status() != WL_CONNECTED) {
Serial.print("."); // Change to an led or something
Serial.println("");
Serial.print("Connected to WiFi network with IP Address: ");
SPI.begin();
// pinMode(RFID_SS_PIN, OUTPUT);
pinMode(SD_SS_PIN, OUTPUT);
pinMode(4, OUTPUT);
switch_to_rfid();
rfid.PCD_Init(); // Init MFRC522
out = new AudioOutputSerialWAV();
mp3 = new AudioGeneratorWAV();
switch_to_sd();
if(! SD.begin(SD_SS_PIN)){
Serial.println("SD ERROR");
return;
switch_to_rfid();
// Authenticate Block
MFRC522::MIFARE_Key key;
for (byte i = 0; i < 6; i++) key.keyByte[i] = 0xFF;
byte block = 1;
MFRC522::StatusCode status;
// Look for new cards
if ( ! rfid.PICC_IsNewCardPresent()){
return;
digitalWrite(4, HIGH);
digitalWrite(4, LOW);
// Verify if the NUID has been readed
if ( ! rfid.PICC_ReadCardSerial()){
return;
Serial.print("Card detected...");
// Is it Really a new cArd?
byte identity[rfid.uid.size];
for(byte i = 0; i < rfid.uid.size; i++){
identity[i] = rfid.uid.uidByte[i];
/* if(! new_card(identity, current_card, rfid.uid.size)){
Serial.println("Not Exactly a new Card");
delay(50);
return;
current_card[i] = identity[i];
Serial.println("Actuaslluy a new Card");
status = rfid.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, block, &key, &(rfid.uid));
if (status != MFRC522::STATUS_OK) {
Serial.print("PCD_Authenticate() failed: ");
Serial.println(rfid.GetStatusCodeName(status));
return;
//READ AND PRINT BLOCK 1
byte buffer[18];
byte size = sizeof(buffer);
status = rfid.MIFARE_Read(block, buffer, &size);
// Did Reading fail?
if (status != MFRC522::STATUS_OK){
Serial.print("Reading failed: ");
Serial.print(rfid.GetStatusCodeName(status));
return;
for(byte i = 0; i < 16; i++){
Serial.print(buffer[i]);
rfid.PCD_StopCrypto1();
rfid.PICC_HaltA();
switch_to_sd();
file = new AudioFileSourceSD();
String albumname = "/" + String(buffer[0]) + String(buffer[1]) + String(buffer[2]) + String(buffer[3]);
if(! SD.exists(albumname)){
Serial.print("Album not found");
return;
//Check WiFi connection status
if(WiFi.status()== WL_CONNECTED){
WiFiClient client;
HTTPClient http;
// Your Domain name with URL path or IP address with path
http.begin(client, serverName);
// Specify content-type header
http.addHeader("Content-Type", "application/json");
// Data to send with HTTP POST
String ledData = "{\"seg\":[{\"col\":[[255,100,200]]}]}";
// Send HTTP POST request
int httpResponseCode = http.POST(ledData);
Serial.print("HTTP Response code: ");
Serial.println(httpResponseCode);
http.end();
else {
Serial.println("WiFi Disconnected");
// Functions
void switch_to_rfid(){
digitalWrite(RFID_SS_PIN, LOW);
digitalWrite(SD_SS_PIN, HIGH);
void switch_to_sd(){
digitalWrite(SD_SS_PIN, LOW);
digitalWrite(RFID_SS_PIN, HIGH);
bool new_card(byte identity[], byte current[], byte size){
for(byte i = 0; i < size; i++){
if(identity[i] != current[i]) return 1;
return 0;
int numberofsongs(String directoryPath) {
File directory = SD.open(directoryPath);
if (!directory || !directory.isDirectory()) {
// If the directory doesn't exist or is not a directory, return -1 as an error indicator.
return -1;
int fileCount = 0;
while (File file = directory.openNextFile()) {
if (String(file.name()).endsWith(ext)) {
fileCount++;
file.close();
directory.close();
return fileCount - 1;
