RFID Tag reader
I modified some code so that the Arduino will light an LED in the event of the proper RFID tag being presented. It doesn’t work, and I can’t fix it. The problem seems to be at the line : if (bytesread == 10, code == tagOne)
Can anyone help?
char tagOne[12] = "0415ED3917";   // put the values for your tags here
int rstPin = 2;
int ledPin = 13;
int val = 0;
char code[10];
int bytesread = 0;
  Serial.begin(2400);
  pinMode(rstPin, OUTPUT);
  pinMode(ledPin, OUTPUT);
  digitalWrite(2, LOW);
  // read in and parse serial data:
  if(Serial.available() > 0) {          // if data available from reader
    if((val = Serial.read()) == 10) {   // check for header
      bytesread = 0;
      while(bytesread<10) {              // read 10 digit code
        if( Serial.available() > 0) {
          val = Serial.read();
          if((val == 10)||(val == 13)) { // if header or stop bytes before the 10 digit reading
            break;                       // stop reading
          code[bytesread] = val;         // add the digit
          bytesread++;                   // ready to read next digit
      if(bytesread == 10, code == tagOne) {              // if 10 digit read is complete
        digitalWrite(ledPin, HIGH);
        Serial.print(code);
I don’t think you can compare arrays like that. The array’s name ‘tagOne’ is a pointer to the first element of the array (I think).
You’d have to rewrite your code to something like:
if ( (bytesread == 10) && (check_for_equal_arrays(code,tagOne,array_length) == 1) ) {
   // do this, do that
char check_for_equal_arrays(char *array1, char *array2, int array_length) {
 int ctr;
 for (ctr = 0; ctr < array_length; ctr++) {
   if ( array1[ctr] == array2[ctr] ) {
     /*  nothing to do */
   else {
     return 0;
 return 1;
Something odd here! What are you trying to do with the comma on this line? There is a comma operator in C (and C++), but it’s rarely used. It discards the value of the first expression (‘bytesread == 10’ in this case) and uses the value of the second expression (‘code == tagOne’).
