Heres the sketch in text format so you dont have to open it in IDE
#include <EEPROM.h>
#include <SPI.h>
#include <MFRC522.h>
#include <Wire.h>
#include <Keypad.h>
int state_bt=1;
int relPin;
int stare=0;
byte COD[10];
byte AUX[10];
int k=0;
String codacces="*123456#";
String codpairing="*654321#";
//nfc
#define RST_PIN 9 // Configurable, see typical pin layout above
#define SS_PIN 10 // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance
#define NEW_UID {0xDE, 0xAD, 0xBE, 0xEF}
MFRC522::MIFARE_Key key;
//lcd
LiquidCrystal_I2C lcd(0x27,16,2);
//TASTATURA
const byte numRows= 4; //number of rows on the keypad
const byte numCols= 3; //number of columns on the keypad
//keymap defines the key pressed according to the row and columns just as appears on the keypad
char keymap[numRows][numCols]=
{'1', '2', '3',},
{'4', '5', '6',},
{'7', '8', '9',},
{'*', '0', '#',}
//Code that shows the the keypad connections to the arduino terminals
byte rowPins[numRows] = {5, A0, 7, 8}; //Rows 0 to 3
byte colPins[numCols]= {2, 3, 4}; //Columns 0 to 3
//initializes an instance of the Keypad class
Keypad myKeypad= Keypad(makeKeymap(keymap), rowPins, colPins, numRows, numCols);
pinMode(A0,OUTPUT);
digitalWrite(A0,HIGH);
pinMode(A3,OUTPUT);
digitalWrite(A3,HIGH);
pinMode(A1,OUTPUT);
digitalWrite(A1,HIGH);
pinMode(A2,OUTPUT);
digitalWrite(A2,LOW);
pinMode(6,OUTPUT);
digitalWrite(6,LOW);
//nfc
Serial.begin(9600); // Initialize serial communications with the PC
Serial.println("What did you say?:");
while (!Serial); // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522 card
for (byte i = 0; i < 6; i++) {
key.keyByte = 0xFF;
- lcd.init();*
- lcd.backlight();*
- lcd.setCursor(0,0);*
- lcd.clear();*
- lcd.print( "LOCKED" );*
void citireNFC(){
- for (byte i =0; i<(mfrc522.uid.size); i++) {*
COD_=mfrc522.uid.uidByte*;
Serial.print("COD");
Serial.print(COD[0]);
Serial.print(COD[1]);
Serial.print(COD[2]);
Serial.print(COD[3]);*_
void pairNFC(){
* Serial.println("COD in pair");*
* Serial.print(COD[0]);*
* Serial.print(COD[1]);*
* Serial.print(COD[2]);*
* Serial.print(COD[3]);*
* long r=0;*
* int c=0;*
* for(int i=1;i<=EEPROM.read(0);i++){*
* switch(i%4){*
* case 1 :{AUX[0]=EEPROM.read(i); break;}*
* case 2 :{AUX[1]=EEPROM.read(i); break;}*
* case 3 :{AUX[2]=EEPROM.read(i); break;}*
* case 0 :{AUX[3]=EEPROM.read(i); break;}*
* if((i)%4==0)*
* {Serial.println(r);*
* if( AUX[0]==COD[0] && AUX[1]==COD[1] && AUX[2]==COD[2] && AUX[3]==COD[3] ){*
* lcd.clear();*
* lcd.setCursor(0,0);*
* lcd.print("CODE ALREADY IN");*
* lcd.setCursor(0,1);*
* lcd.print("SYSTEM");*
* delay(2000);*
* c=1;*
* break;} *
* if(c==0){int ttt=EEPROM.read(0);*
* Serial.println("CODE PAIRED");*
* EEPROM.write(ttt+1,COD[0]);*
* EEPROM.write(ttt+2,COD[1]);*
* EEPROM.write(ttt+3,COD[2]);*
* EEPROM.write(ttt+4,COD[3]);*
* ttt=ttt+4;*
* Serial.println("ttt");*
* Serial.println(ttt);*
* EEPROM.write(0,0);*
* EEPROM.write(0,ttt); *
* lcd.clear();*
* lcd.print("CODE PAIRED");*
* delay(2000);} *
boolean validareNFC(){
* boolean c=false;*
* switch(i%4){*
* if((i)%4==0)*
* if( AUX[0]==COD[0] && AUX[1]==COD[1] && AUX[2]==COD[2] && AUX[3]==COD[3])*
* c=true;*
* return c; *
int comparareCOD(String a)
* if(a.equals(codacces))*
* return 1;*
* else if(a.equals(codpairing)) return 2;*
* else return 0; *
String iaCOD(char x)
{ char vec[10];
* vec[0]=x;*
* lcd.clear();*
* lcd.print('X');*
* for(int i=1;i<8;i++)*
_ {vec*=myKeypad.waitForKey();
lcd.print('X');}
vec[8]=NULL;
String str(vec);
return str;
void loop() {_
* //Start BT autentification*
* if(Serial.available())*
* char c=Serial.read();*
* switch (state_bt) {*
* case 1:*
if(c=='') state_bt=2;
else state_bt=1;
_ break;*_
* case 2:*
* if(c=='1') state_bt=3;
else state_bt=1;
_ break;*_
* case 3:*
* if(c=='2') state_bt=4;
else state_bt=1;
_ break;*_
* case 4:*
* if(c=='3') state_bt=5;
else state_bt=1;
_ break;*_
* case 5:*
* if(c=='4') state_bt=6;
else state_bt=1;
_ break;*_
* case 6:*
* if(c=='5') state_bt=7;
else state_bt=1;
_ break;*_
* case 7:*
* if(c=='6') state_bt=8;
else state_bt=1;
_ break;*_
* case 8:*
* if(c=='#') state_bt=9;
else state_bt=1;
_ break;*_
* case 9:*
* lcd.init(); *
* lcd.backlight();*
* lcd.print("OPEN");*
* digitalWrite(6,LOW);*
* delay(5000);*
* digitalWrite(6,HIGH);*
* lcd.init(); *
* lcd.backlight();*
* lcd.print("BLOCKED");*
* state_bt=1;
_ break;*_
* default:*
* break;*
* //////////END BT Autentification*
* switch(stare){*
* case 0: {*
* mfrc522.PCD_Init();
if ( mfrc522.PICC_IsNewCardPresent() && mfrc522.PICC_ReadCardSerial() ){*
* citireNFC();*
* if(validareNFC()) *
* {stare=1;*
* lcd.clear();*
* lcd.print("VALID NFC CODE");*
* delay(1000);*
* return; *
* else{*
* lcd.clear();*
* lcd.print("INVALID NFC CODE");*
* delay(1000);*
* lcd.clear();*
* return;*
* char c=myKeypad.getKey();*
* if(c != NO_KEY){*
* String codcurent=iaCOD(c);*
* int A=comparareCOD(codcurent);*
* if(A==0)*
* {lcd.clear();*
* lcd.print("INVALID CODE");*
* delay(2000);*
* lcd.clear();*
* return;}*
* if(A==1)*
* {lcd.setCursor(0,0);*
* lcd.clear();*
* lcd.print("VALID CODE");*
* delay(2000);*
* stare = 1;*
* return;}*
* if(A==2);*
* {stare=2;*
* lcd.clear();*
* lcd.print("Pairing...");*
* delay(2000);*
* return;}*
* } break;*
* case 1:{*
* lcd.clear();*
* lcd.print("UNLOCKED");*
* digitalWrite(A3,LOW);*
* digitalWrite(A1,LOW);*
* digitalWrite(A2,HIGH);*
* //tone(6,3000,5010);*
* delay(2000);*
* digitalWrite(A3,HIGH);*
* digitalWrite(A1,HIGH);*
* digitalWrite(A2,LOW);*
* stare=0;*
* lcd.clear();*
* return;*
* case 2:{*
_ citireNFC();
pairNFC();
stare=0;
delay(2000);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("BLOCKED"); }*_
* break;*
