RFID to Control LED
Your code is overly complicated. I've tried to simplify. Note the turn off delay is 15 seconds to make it easier to test.
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_PN532.h>
#define PN532_SCK  (2)
#define PN532_MOSI (3)
#define PN532_SS   (4)
#define PN532_MISO (5)
#define LED 13  // LED connected to pin 13
// Defining pins for I2C for shield
#define PN532_IRQ   (2)
#define PN532_RESET (3)  // Not connected by default on the NFC Shield
// For breakout/shield with I2C connection:
Adafruit_PN532 nfc(PN532_IRQ, PN532_RESET);
// Declaring last recorded time (previousMillis) and latest recorded time (currentMillis)
unsigned long previousMillis = 0;
unsigned long currentMillis = millis(); // millis() is a timer function
void setup(void)
  pinMode(LED, OUTPUT); // Declare the LED as an output
  Serial.begin(115200); // Baud rate
  while (!Serial) delay(10);
  nfc.begin();
  // Shield detection
  uint32_t versiondata = nfc.getFirmwareVersion();
  if (! versiondata) {  // If board not connected or wrong board
    Serial.print("Didn't find PN53x board");
    while (1); // halt
  // If board connected
  Serial.print("Found chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
  Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
  Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
  // Configure board to read RFID tags
  nfc.setPassiveActivationRetries(0x9A);
  nfc.SAMConfig();
  // Standby mode
  Serial.println("Waiting for an ISO14443A Card ...");
boolean onLED = false;
unsigned long onTime = 0;
uint32_t MAX_ON_TIME = 15000;
void loop(void)
  uint8_t success;
  uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 };  // Buffer to store the returned UID
  uint8_t uidLength;                        // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
  // Turn off LED if it has been on for more the maximum time.
  if (onLED && millis() > onTime + MAX_ON_TIME)
    onLED = false;
    onTime = 0;
    digitalWrite(LED, LOW);
  // Wait for an ISO14443A type cards (Mifare, etc.).  When one is found
  // 'uid' will be populated with the UID, and uidLength will indicate
  // if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
  success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);
  if (success)
    nfc.PrintHex(uid, uidLength); // Displays ID of card/tag
    Serial.println("");
    if (uidLength == 4)
      // Card ID
      uint8_t keya[6] = { 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
      // Is this the correct card?
      if (uid[0] == 0x33 && uid[1] == 0x06 && uid[2] == 0x64 && uid[3] == 0x97)
          if (onLED) // Already on, so turn off.
            onLED = false;
            onTime = 0;
          else // Already off, so turn on.
            onLED = true;
            onTime = millis();
            digitalWrite(LED, HIGH);
      delay(500); // Just in case the card keeps getting read again & again.
//    // Start with block 4 (the first block of sector 1) cos sector 0 contains manufacturer data
//      success = nfc.mifareclassic_AuthenticateBlock(uid, uidLength, 4, 0, keya);
//      if (success)
//        uint8_t data[16];
//        // Reading the contents of block 4
//        success = nfc.mifareclassic_ReadDataBlock(4, data);
//        if (success)
//          delay(1000);
