Hi all.
I need to get mifare uid to keyboard using Arduini Micro.
I use the rc522 library and I get a good response using Serial.print.
The problem is that I m not able to send data to keyboard emulating it.
This is the code
- MFRC522 - Library to use ARDUINO RFID MODULE KIT 13.56 MHZ WITH TAGS SPI W AND R BY COOQROBOT.
- The library file MFRC522.h has a wealth of useful info. Please read it.
- The functions are documented in MFRC522.cpp.
- Based on code Dr.Leong ( WWW.B2CQSHOP.COM )
- Created by Miguel Balboa (circuitito.com), Jan, 2012.
- Rewritten by Søren Thing Andersen (access.thing.dk), fall of 2013 (Translation to English, refactored, comments, anti collision, cascade levels.)
- Released into the public domain.
- Sample program showing how to read data from a PICC using a MFRC522 reader on the Arduino SPI interface.
*----------------------------------------------------------------------------- empty_skull
- Aggiunti pin per arduino Mega
- add pin configuration for arduino mega
http://mac86project.altervista.org/
----------------------------------------------------------------------------- Nicola Coppola
- Pin layout should be as follows:
- Signal Pin Pin Pin
- Arduino Uno Arduino Mega MFRC522 board
- Reset 9 5 RST
- SPI SS 10 53 SDA
- SPI MOSI 11 52 MOSI
- SPI MISO 12 51 MISO
- SPI SCK 13 50 SCK
- The reader can be found on eBay for around 5 dollars. Search for "mf-rc522" on ebay.com.
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 10
#define RST_PIN 5
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
Serial.begin(115200); // Initialize serial communications with the PC
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522 card
Keyboard.begin();
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent()) {
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial()) {
return;
for (byte i = 0; i < mfrc522.uid.size; i++) {
Serial.print(mfrc522.uid.uidByte < 0x10 ? " 0" : " ");
_ Keyboard.print((mfrc522.uid.uidByte < 0x10 ? " 0" : " "));_
_ Serial.print(mfrc522.uid.uidByte*, HEX);*
On pc text i get only spaces. I think its a casting problem, that s true? How can I solve that?
Thanks
