Hey guys, can someone tell me how can I code the arduino to do this:
-pass card
-open door (relay 1)
-pass card
close door (relay 2)
so far I have de first part (open door) working but I can't make the second part work, and i've been looking online but I can't find nothing, can someone help me?
so, my objective is to open with the first card swipe reading, and close with the second same card swipe,
and yes i am new at arduino programing, i know a little bit about electronics but this is my first time using arduino and programing
as is, when I swipe the card it sends the signal to relay 1 to open, and half a second later to the second to close...I would like to send the comand to close only with a second card swipe
if someone can help me i would thank you
this is what I have so far:
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN);Â // Create MFRC522 instance.
#define RELAY1Â 6
#define RELAY2Â 5
 Serial.begin(9600); // Initiate a serial communication
 SPI.begin();   // Initiate SPI bus
 mfrc522.PCD_Init(); // Initiate MFRC522
 Serial.println("Approximate your card to the reader...");
Â
 // Initialise the Arduino data pins for OUTPUT
 pinMode(RELAY1, OUTPUT);
 pinMode(RELAY2, OUTPUT);
Â
 // Look for new cards
 if ( ! mfrc522.PICC_IsNewCardPresent())
  return;
 // Select one of the cards
 if ( ! mfrc522.PICC_ReadCardSerial())
  return;
 //Show UID on serial monitor
 Serial.print("UID tag :");
 String content= "";
 byte letter;
 for (byte i = 0; i < mfrc522.uid.size; i++)
  Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
  Serial.print(mfrc522.uid.uidByte[i], HEX);
  content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
  content.concat(String(mfrc522.uid.uidByte[i], HEX));
 Serial.print("Message : ");
 content.toUpperCase();
 if (content.substring(1) == "83 9B B1 AB" || content.substring(1) == "16 AF 86 A5") //change here the UID of the card/cards that you want to give access
  Serial.println("Open");
  delay(100);
  digitalWrite(RELAY1,HIGH);     // Turns ON Relay 1
  delay(500);                   // Wait 1\2 second
  digitalWrite(RELAY1,LOW);     // Turns Relay Off
else (content.substring(1) == "83 9B B1 AB" || content.substring(1) == "16 AF 86 A5") //change here the UID of the card/cards that you want to give access
;Â {
  Serial.println("Closed");
  delay(100);
  digitalWrite(RELAY2,HIGH);     // Turns ON Relay 2
  digitalWrite(RELAY2,LOW);     // Turns Relay Off
How many times do you need to set the pins to output? The correct answer is ONCE.
The example you started from is garbage. If there is not a card present, and it is not a new card, the Arduino does NOTHING except uselessly set the mode of two pins to output, on every pass through loop().
thanks for your repply,
like I said, I'm new at this...
if this is garbage can you tell me a good example to start from?
is it that hard to achieve what i'm trying to achieve?
IRSantos8:
It does look a bit dodgy, but you may learn something from it nonetheless.
Try fixing the else if as recommended by PaulS - as well as removing the spurious ; on the next line - and see what happens.
when I remove the ";" and put the "else if" relay 1 works with the first swipe and opens, but any other swipe it repeat the open with relay 1, and not "close" with relay 2
i'm sorry if I'm not understanding what you are trying to tell me, i'm portuguese, and my english is a bit rusty
i'm what to achieve a working code to open and close my car doors swiping de card or the key chain to open and close with the 2 relays
  delay(100);
  digitalWrite(RELAY1,HIGH);     // Turns ON Relays 1
  delay(500);                   // Wait 1\2 seconds
else if (content.substring(2) == "83 9B B1 AB" || content.substring(2) == "16 AF 86 A5") //change here the UID of the card/cards that you want to give access
  delay(100);
  digitalWrite(RELAY2,HIGH);     // Turns ON Relays 1
No, you understand just fine, don't worry about that.
What is missing from your code is knowledge of whether the door is open or whether it is closed.
Probably the best option would be in hardware; so a switch that detects whether the door is open or closed and then your sketch can read the state of the switch.
Alternatively, for the quick and dirty software approach, you can assume that the door is closed at the beginning of the sketch (when the Arduino is turned on), or even perhaps force close it.
You need a global variable to store the door state, eg. bool isDoorOpen = false;
Then, when a valid card is swiped, you check if the door is open or closed and act accordingly, toggling the value of isDoorOpen afterwards.
You only need a simple if block to check if the card is valid. Then the if...else for the isDoorOpen part.
thank you arduarn,
i'm going to try what you said, I don't know to code those things yet, but i'll try to learn
the other option I can think is if the car central locking has a module that suports only one signal to open and close, i'm gonna try to find out, if it does i can do it with only one relay instead
