RFID UART wont read
Hey, first of all, i'm not sure if this is the right forum to post this in, but anyhow here we go:
I've bought this rfid reader:
http://let-elektronik.dk/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=216&category_id=38&option=com_virtuemart&Itemid=94
and this tag:
http://let-elektronik.dk/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=218&category_id=38&option=com_virtuemart&Itemid=94
But for some reason i cant find anything that gives me an example on how to use it.
I just need a simple program that will allow me to read that tag, but the examples i've found so far doesn't work.
Please help me, oh wise ones!
That RFID reader looks a lot like the one that seeedstudio sells. When you power up the Arduino, does the LED on the reader come on? When you scan the tag, does the LED flash?
This is code I use to read from my seeedstudio RFID reader:
#include <SoftwareSerial.h>
#define rxPin 2
#define txPin 3
//create a Serial object RFID
SoftwareSerial RFID = SoftwareSerial(rxPin, txPin);
char code[20];
int val = 0;
int bytesread = 0;
char Red[]    = "3900A52D9223";
char Blue[]   = "39009F46D131";
char Yellow[] = "390050448FA2";
char Card1[]  = "210014E221F6";
char Card2[]  = "210014C9906C";
int ledCnt = 5;
int LED[] = {13, 11, 9, 7, 5};
  Serial.begin(9600); //open serial hardware
  RFID.begin(9600); //open serial software
  pinMode(rxPin, INPUT); //set pin on arduino for receiving RFID data
  pinMode(txPin, OUTPUT); //this is not important
  for(int i=0; i<ledCnt; i++)
    pinMode(LED[i], OUTPUT);
  val = 0;
  bytesread = 0;
  while(bytesread < 12)
    // read 12 digit code
    val = RFID.read();
    if(val == 3)
    { // if header or stop bytes before the 10 digit reading
      break; // stop reading
    if(val != 2)
      code[bytesread] = val; // add the digit
      bytesread++; // ready to read next digit
      code[bytesread] = '\0'; // add the NULL
  if(bytesread >= 12)
  { // if 12 digit read is complete
    Serial.print("Tag: [");
    for(int i=0; i<bytesread; i++)
      Serial.print(code[i]);
    Serial.println("]"); //print the whole 13 bytes
    int tag = FindValidTag(code);
    Serial.print("Tag number: ");
    Serial.println(tag);
      digitalWrite(LED[i], LOW);
    if(tag > 0 && tag <= ledCnt)
      digitalWrite(LED[tag-1], HIGH);
int FindValidTag(char *code)
  if(strcmp(code, Red) == 0)
    return 1;
  else if(strcmp(code, Blue) == 0)
    return 2;
  else if(strcmp(code, Yellow) == 0)
    return 3;
  else if(strcmp(code, Card1) == 0)
    return 4;
  else if(strcmp(code, Card2) == 0)
    return 5;
    return 0;
im not even sure i've wired it correctly :S
Could you give me a quick discription of how to wire it up corretly? :slight_smile:
i've wired it correctly, BUT it doesn't read...
Could it be the wrong tag i'm using?
Even tho it says its 125Khz, like the reader, but could it still not work?
