RFID UID Logger
Hello, I'm trying to make a small device that will store the UID value of a RFID card on a SD card.
I have tried to combine two codes to option the following cod but for some unknown reasons it doesn't work for me :frowning: Please help me.
//Libs
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_PN532.h>
#include <SPI.h>
#include <SD.h>
//File
File myFile;
//Define
#define PN532_SCK  (2)
#define PN532_MOSI (3)
#define PN532_SS   (9)
//4
#define PN532_MISO (5)
//Other
Adafruit_PN532 nfc(PN532_SCK, PN532_MISO, PN532_MOSI, PN532_SS);
//Void
void setup(void)
//SD Initialization
  Serial.print("Initializing SD card...");
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  Serial.println("PN532 = Lisening");
//NFC Initialization
  nfc.begin();
  uint32_t versiondata = nfc.getFirmwareVersion();
  if (! versiondata) {
    Serial.print("Didn't find PN53x board");
    while (1); // halt
  // Got ok data, print it out!
  Serial.print("Found chip PN5");
  Serial.println((versiondata>>24) & 0xFF, HEX);
  Serial.print("Firmware ver. ");
  Serial.print((versiondata>>16) & 0xFF, DEC);
  Serial.print('.');
  Serial.println((versiondata>>8) & 0xFF, DEC);
// configure board to read RFID tags
  nfc.SAMConfig();
  Serial.println("Waiting for an ISO14443A Card ...");
void loop(void)
  myFile = SD.open("test.txt", FILE_WRITE);
  if (myFile)
    uint8_t success;
    uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 };  // Buffer to store the returned UID
    uint8_t uidLength;                        // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
  // Wait for an ISO14443A type cards (Mifare, etc.).  When one is found
  // 'uid' will be populated with the UID, and uidLength will indicate
  // if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
  success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);
  if (success) {
    // Display some basic information about the card
    Serial.println("Found an ISO14443A card");
    myFile.println("Found an ISO14443A card");
    Serial.print("  UID Length: ");
    myFile.print("  UID Length: ");
    Serial.print(uidLength, DEC);
    myFile.print(uidLength, DEC);
    Serial.println(" bytes");
    myFile.println(" bytes");
    Serial.print("  UID Value: ");
    myFile.print("  UID Value: ");
    nfc.PrintHex(uid, uidLength);
    Serial.println("");
    myFile.println("");
    if (uidLength == 4)
      // We probably have a Mifare Classic card ...
      Serial.println("Seems to be a Mifare Classic card (4 byte UID)");
      myFile.println("Seems to be a Mifare Classic card (4 byte UID)");
      // Now we need to try to authenticate it for read/write access
      // Try with the factory default KeyA: 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
      Serial.println("Trying to authenticate block 4 with default KEYA value");
      myFile.println("Trying to authenticate block 4 with default KEYA value");
      uint8_t keya[6] = { 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF };
    // Start with block 4 (the first block of sector 1) since sector 0
    // contains the manufacturer data and it's probably better just
    // to leave it alone unless you know what you're doing
      success = nfc.mifareclassic_AuthenticateBlock(uid, uidLength, 4, 0, keya);
      if (success)
        Serial.println("Sector 1 (Blocks 4..7) has been authenticated");
        myFile.println("Sector 1 (Blocks 4..7) has been authenticated");
        uint8_t data[16];
        // If you want to write something to block 4 to test with, uncomment
    // the following line and this text should be read back in a minute
        //memcpy(data, (const uint8_t[]){ 'a', 'd', 'a', 'f', 'r', 'u', 'i', 't', '.', 'c', 'o', 'm', 0, 0, 0, 0 }, sizeof data);
        // success = nfc.mifareclassic_WriteDataBlock (4, data);
        // Try to read the contents of block 4
        success = nfc.mifareclassic_ReadDataBlock(4, data);
        if (success)
          // Data seems to have been read ... spit it out
          Serial.println("Reading Block 4:");
          myFile.println("Reading Block 4:");
          nfc.PrintHexChar(data, 16);
          Serial.println("");
          myFile.println("");
          // Wait a bit before reading the card again
          Serial.println("Ooops ... unable to read the requested block.  Try another key?");
          myFile.println("Ooops ... unable to read the requested block.  Try another key?");
        Serial.println("Ooops ... authentication failed: Try another key?");
        myFile.println("Ooops ... authentication failed: Try another key?");
    if (uidLength == 7)
      // We probably have a Mifare Ultralight card ...
      Serial.println("Seems to be a Mifare Ultralight tag (7 byte UID)");
      myFile.println("Seems to be a Mifare Ultralight tag (7 byte UID)");
      // Try to read the first general-purpose user page (#4)
      Serial.println("Reading page 4");
      myFile.println("Reading page 4");
      uint8_t data[32];
      success = nfc.mifareultralight_ReadPage (4, data);
      if (success)
        nfc.PrintHexChar(data, 4);
        Serial.println("");
        myFile.println("");
        Serial.println("Ooops ... unable to read the requested page!?");
        myFile.println("Ooops ... unable to read the requested page!?");
    myFile.close();
    // if the file didn't open, print an error:
    Serial.println("error opening test.txt");
