rfid wiegand 26 with 8x8 matrix
Hello:
i am quite a newbie at programming. i want to do is that when the rfid reader read the tag , all the led off.
String comdata="";
int speed = 80; //number of times to repeat each frame
int pauseDelay = 200;
//microseconds to leave each row  on before moving to the next
//The string to display
//to change the message in code you right yourself simply
//change this data and reset index and offset to 0
//Variables used for scrolling (both start at 0
int index = 0;  //this is the current charachter in the string being displayed
int offset = 0; //this is how many columns it is offset by
//Pin Definitions
int rowA[] = {
 31,30,33,32,35,34,37,36};          //An Array defining which pin each row is attached to
//(rows are common anode (drive HIGH))
int colA[] = {
  40, 41, 38, 39, 51, 50, 52, 53};  //An Array defining which pin each column is attached to
//(columns are common cathode (drive LOW))
//Constants defining each charachters position in an array of integer arrays
//Letters
volatile long reader1 = 0;
volatile int reader1Count = 0;
void reader1One(void) {
  reader1Count++;
  reader1 = reader1 << 1;
  reader1 |= 1;
void reader1Zero(void) {
  reader1Count++;
const int A = 0;
const int B = 1;
const int C = 2;
const int D = 3;
const int E = 4;
const int F = 5;
const int G = 6;
const int H = 7;
const int I = 8;
const int J = 9;
const int K = 10;
const int L =11;
const int M = 12;
const int N = 13;
const int O = 14;
const int P = 15;
const int Q =16;
const int R = 17;
const int S = 18;
const int T = 19;
const int U = 20;
const int V =21;
const int W = 22;
const int X = 23;
const int Y = 24;
const int Z = 25;
const int num1 = 38;
const int num2 = 39;
const int num3 = 40;
const int num4 = 41;
const int num5 = 42;
const int num6 = 43;
const int num7 = 44;
const int num8 = 45;
const int num9 = 46;
const int num0 = 47;
//Punctuation
const int COL =26;
const int DASH = 27;
const int BRA2 = 28;
const int  _ = 29;
const int LINE = 34;
const int DOT =36;
//Extra Charchters
const int  FULL =30;
const int CHECK = 31;
const int B2 = 32;
const int TEMP =33;
const int SMILE =35;
const int COLDOT = 37;
//The array used to hold a bitmap of the display
//(if you wish to do something other than scrolling marque change the data in this
//variable then display)
byte data[] = {
  0,0,0,0,0,0,0,0};
//The alphabet
//Each Charachter is an 8 x 7 bitmap where 1 is on and 0 if off
const int _A[] = {
  B0001000,
  B0010100,
  B0100010,
  B1000001,
  B1111111,
  B1000001,
  B1000001,
  B0000000};
const int _B[] = {
  B1111110,
  B0100001,
  B0100001,
  B0111110,
  B0100001,
  B0100001,
  B1111110,
  B0000000};
const int _C[] = {
  B0011111,
  B0100000,
  B1000000,
  B1000000,
  B1000000,
  B0100000,
  B0011111,
  B0000000};
const int _D[] = {
  B1111100,
  B0100010,
  B0100001,
  B0100001,
  B0100001,
  B0100010,
  B1111100,
  B0000000};
const int _E[] = {
  B1111111,
  B1000000,
  B1000000,
  B1111100,
  B1000000,
  B1000000,
  B1111111,
  B0000000};
const int _F[] = {
  B1111111,
  B1000000,
  B1000000,
  B1111100,
  B1000000,
  B1000000,
  B1000000,
  B0000000};
const int _G[] = {
  B0011111,
  B0100000,
  B1000000,
  B1001111,
  B1000001,
  B0100001,
  B0011111,
  B0000000};
const int _H[] = {
  B1000001,
  B1000001,
  B1000001,
  B1111111,
  B1000001,
  B1000001,
  B1000001,
  B0000000};
const int _I[] = {
  B1111111,
  B0001000,
  B0001000,
  B0001000,
  B0001000,
  B0001000,
  B1111111,
  B0000000};
const int _J[] = {
  B0001111,
  B0000001,
  B0000001,
  B0000001,
  B0000001,
  B1000001,
  B0111110,
  B0000000};
const int _K[] = {
  B1000011,
  B1000100,
  B1001000,
  B1110000,
  B1001000,
  B1000100,
  B1000011,
  B0000000};
const int _L[] = {
  B1000000,
  B1000000,
  B1000000,
  B1000000,
  B1000000,
  B1000000,
  B1111111,
  B0000000};
const int _M[] = {
  B1110110,
  B1001001,
  B1001001,
  B1001001,
  B1001001,
  B1001001,
  B1001001,
  B0000000};
const int _N[] = {
  B1000001,
  B1100001,
  B1010001,
  B1001001,
  B1000101,
  B1000011,
  B1000001,
  B0000000};
const int _O[] = {
  B0011100,
  B0100010,
  B1000001,
  B1001001,
  B1000001,
  B0100010,
  B0011100,
  B0000000};
const int _P[] = {
  B1111110,
  B0100001,
  B0100001,
  B0111110,
  B0100000,
  B0100000,
  B0100000,
  B0000000};
const int _Q[] = {
  B0011100,
  B0100010,
  B1000001,
  B1000001,
  B1000101,
  B0100010,
  B0011101,
  B0000000};
const int _R[] = {
  B1111110,
  B0100001,
  B0100001,
  B0101110,
  B0100100,
  B0100010,
  B0100001,
  B0000000};
const int _S[] = {
  B0111111,
  B1000000,
  B1000000,
  B0111110,
  B0000001,
  B0000001,
  B1111110,
  B0000000};
const int _T[] = {
  B1111111,
  B0001000,
  B0001000,
  B0001000,
  B0001000,
  B0001000,
  B0001000,
  B0000000};
const int _U[] = {
  B1000001,
  B1000001,
  B1000001,
  B1000001,
  B1000001,
  B1000001,
  B0111110,
  B0000000};
const int _V[] = {
  B1000001,
  B1000001,
  B1000001,
  B1000001,
  B0100010,
  B0010100,
  B0001000,
  B0000000};
const int _W[] = {
  B1000001,
  B1001001,
  B1001001,
  B1001001,
  B1001001,
  B1001001,
  B0110110,
  B0000000};
const int _X[] = {
  B1000001,
  B0100010,
  B0010100,
  B0001000,
  B0010100,
  B0100010,
  B1000001,
  B0000000};
const int _Y[] = {
  B1000001,
  B0100010,
  B0010100,
  B0001000,
  B0001000,
  B0001000,
  B0001000,
  B0000000};
const int _Z[] = {
  B1111111,
  B0000010,
  B0000100,
  B0001000,
  B0010000,
  B0100000,
  B1111111,
  B0000000};
const int _COL[] = {
  B0000000,
  B0011000,
  B0011000,
  B0000000,
  B0011000,
  B0011000,
  B0000000,
  B0000000};
const int _DASH[] = {
  B0000000,
  B0000000,
  B0000000,
  B0111110,
  B0000000,
  B0000000,
  B0000000,
  B0000000};
const int _BRA2[] = {
  B0010000,
  B0001000,
  B0000100,
  B0000100,
  B0001000,
  B0010000,
  B0000000,
  B0000000};
const int __[] = {
  B0000000,
  B0000000,
  B0000000,
  B0000000,
  B0000000,
  B0000000,
  B0000000,
  B0000000};
const int _FULL[] = {
  B00000000,
  B00000000,
  B00000000,
  B00000000,
  B00000000,
  B00000000,
  B00000000,
  B00000000};
const int _CHECK[] = {
  B1010101,
  B0101010,
  B1010101,
  B0101010,
  B1010101,
  B0101010,
  B1010101,
  B0000000};
const int _B2[] = {
  B0111110,
  B0000001,
  B0000001,
  B0001111,
  B0000001,
  B1000001,
  B0111110,
  B0000000};
const int _TEMP[] = {
  B0000011,
  B0011111,
  B0111111,
  B1111110,
  B1111111,
  B0011111,
  B0000011,
  B0000000};
const int _LINE[] = {
  B0000001,
  B0000001,
  B0000001,
  B0000001,
  B0000001,
  B0000001,
  B0000001,
  B0000000};
const int _SMILE[] = {
  B0000000,
  B0000000,
  B0000000,
  B0000000,
  B0000000,
  B0000000,
  B0000000,
  B0000000};
const int _DOT[] = {
  B0000000,
  B0000000,
  B0000000,
  B0000000,
  B1100000,
  B1100000,
  B0000000,
  B0000000};
const int _COLDOT[] = {
  B0000000,
  B0110000,
  B0110000,
  B0000000,
  B0110011,
  B0110011,
  B0000000,
  B0000000};
const int _num1[] = {
  B0001000,
  B0011000,
  B0101000,
  B0001000,
  B0001000,
  B0001000,
  B1111111,
  B0000000};
const int _num2[] = {
  B0001100,
  B0010010,
  B0100100,
  B0001000,
  B0010000,
  B0100000,
  B1111111,
  B0000000};
const int _num3[] = {
  B1111111,
  B1000011,
  B0000011,
  B0011111,
  B0001011,
  B0000011,
  B0000011,
  B1111111};
const int _num4[] = {
  B00001100,
  B00011100,
  B01101100,
  B11001100,
  B11111111,
  B11111111,
  B00001100,
  B0000110};
const int _num5[] = {
  B01111100,
  B01100000,
  B01100000,
  B01110000,
  B00011000,
  B00001110,
  B00001100,
  B00111000};
const int _num6[] = {
  B1111111,
  B1111111,
  B1100000,
  B1100000,
  B1111111,
  B1100011,
  B1100011,
  B1111111};
const int _num7[] = {
  B1111111,
  B1111111,
  B0000011,
  B0000011,
  B0000011,
  B0000011,
  B0000011,
  B0000011};
const int _num8[] = {
  B1111111,
  B1100011,
  B1100011,
  B1111111,
  B1100011,
  B1100011,
  B1100011,
  B1111111};
const int _num9[] = {
  B1111111,
  B1000001,
  B1000001,
  B1111111,
  B0000001,
  B0000001,
  B0000001,
  B1111111};
const int _num0[] = {
  B0111111,
  B0100001,
  B0100011,
  B0100101,
  B0101001,
  B0110001,
  B0111111,
  B0111111};
//Load the bitmap charachters into an array (each charachters position corresponds to its previously defined index (ie _A (a's bitmap
//is at index 0 and A = 0 so letters[A] will return the 'A' bitmap)
const int* letters[] = {
  _A,_B,_C,_D,_E,_F,_G,_H,_I,_J,_K,_L,_M,_N,_O,_P,_Q,_R,_S,_T,_U,_V,_W,_X,_Y,_Z,_COL,_DASH,_BRA2,__, _FULL, _CHECK, _B2, _TEMP, _LINE, _SMILE, _DOT, _COLDOT,_num1,_num2,_num3,_num4,_num5,_num6,_num7,_num8,_num9,_num0};
//Setup runs once when power is applied
    attachInterrupt(0, reader1Zero, RISING);//DATA0 to pin 2
  attachInterrupt(1, reader1One, RISING); //DATA1 to pin 3
  delay(10);
  // the interrupt in the Atmel processor mises out the first negitave pulse as the inputs are already high,
  // so this gives a pulse to each reader input line to get the interrupts working properly.
  // Then clear out the reader variables.
  // The readers are open collector sitting normally at a one so this is OK
  for(int i = 2; i<4; i++){
  pinMode(i, OUTPUT);
   digitalWrite(i, HIGH); // enable internal pull up causing a one
  digitalWrite(i, LOW); // disable internal pull up causing zero and thus an interrupt
  pinMode(i, INPUT);
  delay(10);
  // put the reader input variables to zero
  reader1 = 0;
  reader1Count = 0;
  //digitalWrite(13, HIGH);  // show Arduino has finished initilisation
  for(int i = 0; i <8; i++){  //Set the 16 pins used to control the array as OUTPUTs
    pinMode(rowA[i], OUTPUT);
    pinMode(colA[i], OUTPUT);
//repeats
  comdata1();
  updateMatrix();
 rfid();
void comdata1(){
  while (Serial.available() > 0)
    comdata += char(Serial.read());
    delay(2);
   void rfid(){
  if(reader1Count >=26){
//Serial.print(" Reader 1 ");
//Serial.println(reader1,HEX);
 // Serial.println("A");
 //Serial.println(reader1& 0xfffffff);
 int serialNumber=(reader1 >> 1) & 0x3fff;
 int siteCode= (reader1 >> 17) & 0x3ff;
  reader1 = 0;
  reader1Count = 0;
switch (siteCode)
  case 188:
String comdata="" ;
void updateMatrix(){
  loadSprite();
  showSprite(speed);
//An array holding the powers of 2 these are used as bit masks when calculating what to display
const int powers[] = {
  1,2,4,8,16,32,64,128};
//Loads the current scroll state frame into the data[] display array
void loadSprite(){
  int currentChar = getChar(comdata[index]);
  int nextChar = getChar(comdata[index+1]);
  for(int row=0; row < 8; row++){                    //iterate through each row
    data[row] = 0;                                   //reset the row we're working on
    for(int column=0; column < 8; column++){         //iterate through each column
      data[row] = data[row] + ((powers[column] & (letters[currentChar][row] << offset)));   //loads the current charachter offset by offset pixels
      data[row] = data[row] + (powers[column] & (letters[nextChar][row] >> (8-offset) ));   //loads the next charachter offset by offset pixels
  offset++;                                          //increment the offset by one row
  if(offset==8){
    offset = 0;
    index++;
    if(index==sizeof(comdata)-2){
      index=0;
  }         //if offset is 8 load the next charachter pair for the next time through
void showSprite(int speed2){
  for(int iii = 0; iii < speed2; iii++){                 //show the current frame speed2 times
    for(int column = 0; column < 8; column++){            //iterate through each column
      for(int i = 0; i < 8; i++){
        digitalWrite(rowA[i], HIGH);                      //turn off all row pins
      for(int i = 0; i < 8; i++){ //Set only the one pin
        if(i == column){
          digitalWrite(colA[i], HIGH);
        }  //turns the current row on
        else{
          digitalWrite(colA[i], LOW);
        }//turns the rest of the rows off
      for(int row = 0; row < 8; row++){                    //iterate through each pixel in the current column
        int bit = (data[column] >> row) & 1;
        if(bit == 1){
          digitalWrite(rowA[row], LOW);                   //if the bit in the data array is set turn the LED on
      delayMicroseconds(pauseDelay);                       //leave the column on for pauseDelay microseconds (too high a delay causes flicker)
//returns the index of a given charachter
//for converting from a string to a lookup in our array of charachter bitmaps
int getChar(char charachter){
  int returnValue = FULL;
  switch(charachter){
  case 'A':
    returnValue = A;
  case 'a':
    returnValue = A;
  case 'B':
    returnValue = B;
  case 'b':
    returnValue = B;
  case 'C':
    returnValue = C;
  case 'c':
    returnValue = C;
  case 'D':
    returnValue = D;
  case 'd':
    returnValue = D;
  case 'E':
    returnValue = E;
  case 'e':
    returnValue = E;
  case 'F':
    returnValue = F;
  case 'f':
    returnValue = F;
  case 'G':
    returnValue = G;
  case 'g':
    returnValue = G;
  case 'H':
    returnValue = H;
  case 'h':
    returnValue = H;
  case 'I':
    returnValue = I;
  case 'i':
    returnValue = I;
  case 'J':
    returnValue = J;
  case 'j':
    returnValue = J;
  case 'K':
    returnValue = K;
  case 'k':
    returnValue = K;
  case 'L':
    returnValue = L;
  case 'l':
    returnValue = L;
  case 'M':
    returnValue = M;
  case 'm':
    returnValue = M;
  case 'N':
    returnValue = N;
  case 'n':
    returnValue = N;
  case 'O':
    returnValue = O;
  case 'o':
    returnValue = O;
  case 'P':
    returnValue = P;
  case 'p':
    returnValue = P;
  case 'Q':
    returnValue = Q;
  case 'q':
    returnValue = Q;
  case 'R':
    returnValue = R;
  case 'r':
    returnValue = R;
  case 'S':
    returnValue = S;
  case 's':
    returnValue = S;
  case 'T':
    returnValue = T;
  case 't':
    returnValue = T;
  case 'U':
    returnValue = U;
  case 'u':
    returnValue = U;
  case 'V':
    returnValue = V;
  case 'v':
    returnValue = V;
  case 'W':
    returnValue = W;
  case 'w':
    returnValue = W;
  case 'X':
    returnValue = X;
  case 'x':
    returnValue = X;
  case 'Y':
    returnValue = Y;
  case 'y':
    returnValue = Y;
  case 'Z':
    returnValue = Z;
  case 'z':
    returnValue = Z;
  case ' ':
    returnValue = _;
  case '~':
    returnValue = B2;
  case '<':
    returnValue = TEMP;
  case '*':
    returnValue = FULL;
  case '|':
    returnValue = LINE;
  case '_':
    returnValue = _;
  case ':':
    returnValue = COL;
  case '-':
    returnValue = DASH;
  case ')':
    returnValue = BRA2;
  case '%':
    returnValue = SMILE;
  case '.':
    returnValue = DOT;
  case '^':
    returnValue = COLDOT;
  case '1':
    returnValue = num1;
  case '2':
    returnValue = num2;
  case '3':
    returnValue = num3;
      case '4':
    returnValue = num4;
  case '5':
    returnValue = num5;
  case '6':
    returnValue = num6;
      case '7':
    returnValue = num7;
  case '8':
    returnValue = num8;
  case '9':
    returnValue = num9;
      case '0':
    returnValue = num0;
 return returnValue;}
but i cannot do that , can any one can help me?
You’ve already posted most of that code today.
Have you tested the code to read the reader?
Just saying “I cannot do that” isn’t really very helpful.
