RFID with Limit Switch
Hi friends, i need help about programming here my project is using RFID to Active Motor Servo and waiting until limit switch pressed then Motor servo turn back, i need to use Limit swicth for change the color of led. Here is my primary code :
void loop ()
  int successRead;
  do
    successRead = getID();
  while (!successRead);
  if (isMaster(readCard)) // if card match
    Serial.println("Go in");
    Serial.println("");
    Serial.println("===================================================");
    Serial.println("");
    digitalWrite(b, LOW); // LED Blue change to...
    digitalWrite(g, HIGH); // LED Green on
    beep3(buzz); // buzz on
    c=90;      //servo angle
    d=40;       //delay servo
     for (a=0;a<=c;a+=5)
        servo1.write(a);
        delay(d);
 //LIMIT SWITCH --<<< Here is my problem
    val = digitalRead(inLimit);
    Serial.println(val);
      if(val == HIGH){
       Serial.println("test");
         for (a=c;a>0;a-=5) // servo turn back
            servo1.write(a);
            delay(d);
        digitalWrite(b, HIGH); // LED Blue again
        digitalWrite(g, LOW); // Green off
  else // if card not match
    Serial.println("Warning");
    Serial.println("");
    Serial.println("");
    digitalWrite(r, HIGH); // LED red active,
    beep2(buzz); // Buzzer long,
    digitalWrite(b, HIGH); // then LED blue On again
    digitalWrite(r, LOW); // LED Red off
My problem is in execution for Limit Switch , when i give my
  1. RFID card matched
  2. LED from BLUE change to GREEN ON
  3. then LED GREEN ON and waiting until the Limit Switch is pressed
  4. When i press Limit switch thats nothing change (i mean still in LED GREEN ON)
  5. I try to press limit switch again still nothing changes.
Thats my problem, maybe anyone can help me about my script. Thanks for attention. Sry about my english is not good.
Welcome to the forum.
Please post your complete code please.
Thanks.. Tom.. :slight_smile:
TomGeorge:
Here is my complete code Mr. Tom ,
#include <EEPROM.h> // Library EEPROM
#include <SPI.h> // Library SPI
#include <MFRC522.h> // Library MFRC522
#include <Servo.h> // Library Servo
boolean match = false;
boolean programMode = false;
byte storedCard[4];
byte readCard[4];
byte masterCard[4] = {0x47,0x32,0x13,0x3B}; // UID Card with : 47 32 13 3B
byte masterCard2[4]={0x72,0xA1,0xB6,0xED};
byte gantungan[4]={0x39,0xCD,0x5A,0x9E};
int r = 4; // Pin Red  LED RGB
int g = 3; // Pin Green  LED RGB
int b = 2; // Pin Blue LED RGB
int a,c,d;
int buzz = 5; // Pin data  buzzer
Servo servo1; // Servo name "servo1"
int inLimit = 7; //limit switch pin
int val = 0;
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN);
  SPI.begin();
  mfrc522.PCD_Init();
  Serial.println("===== KEY AUTOMATIC WITH RFID =====");
  Serial.println("");
  Serial.println("Scan your CARD !");
  Serial.println("");
  pinMode(buzz, OUTPUT);
  pinMode(r, OUTPUT);
  pinMode(g, OUTPUT);
  pinMode(b, OUTPUT);
  pinMode(inLimit, INPUT);
  servo1.attach(6);
  servo1.write(20);
void loop ()
  int successRead;
  do
  if (isMaster(readCard)) // card = match?
    Serial.println("");
    Serial.println("");
    digitalWrite(b, LOW); // LED blue OFF
    digitalWrite(g, HIGH); // LED Green ON
    beep3(buzz); // Buzzer active
    c=90;      //servo angle
    d=40;       //speed servo
     for (a=0;a<=c;a+=5)
        servo1.write(a);
        delay(d);
    delay(5000); // delay 5s
    //LIMIT SWITCH <<<<<<<<<<<<<< Here is my problem <<<<
      if(val == HIGH){
         for (a=c;a>0;a-=5)// motor servo turn back
            servo1.write(a);
            delay(d);
        digitalWrite(b, HIGH); // LED Blue is ON again
  else // not match CARD :
    Serial.println("Warning !!");
    Serial.println("");
    Serial.println("");
    digitalWrite(r, HIGH); // LED red ON,
    beep2(buzz); // Buzzer is active
    digitalWrite(b, HIGH); // LED Blue ON again.
int getID()
  if ( ! mfrc522.PICC_IsNewCardPresent())
    return 0;
  if ( ! mfrc522.PICC_ReadCardSerial())
    return 0;
  Serial.print("ID NUMBER : ");
    for (byte i = 0; i < mfrc522.uid.size; i++) {
      readCard[i] = mfrc522.uid.uidByte[i];
      Serial.print(readCard[i], HEX);
  Serial.println("");
  Serial.println("");
  mfrc522.PICC_HaltA();
  return 1;
void readID( int number ) {
  int start = (number * 4 ) - 3;
    for ( int i = 0; i < 4; i++ ) {
      storedCard[i] = EEPROM.read(start+i);
boolean checkTwo ( byte a[], byte b[] ) {
  if ( a[0] != NULL ) {
    match = true;
      for ( int k = 0; k < 4; k++ ) {
        if ( a[k] != b[k] )
        match = false;
  if ( match ) {
    return true;
  else  {
    return false;
boolean isMaster( byte test[] ) {
  if ( checkTwo( test, masterCard ) )
    return true;
  else if ( checkTwo( test, masterCard2 ) )
    return true;
  else if ( checkTwo( test, gantungan ) )
    return true;
    return false;
void beep2(int x) // long beepbeep
  digitalWrite(x, HIGH);
  digitalWrite(x, LOW);
void beep3(int x) // short beep
  delay(50);
  delay(50);
  delay(50);
  delay(50);
  delay(50);
  delay(50);
  delay(50);
  delay(50);
Wait i forget about my hand drawn circuit ,sorry Mr. Tom
Here is my schematic guys
https://postimg.org/image/6jzp7dszn/
OPs Diag
Hmmm...
Tom... :o
Its not the easiest to read, and you have no current limit resistors on the LEDs.
A picture of a hand drawn schematic would be better, keeping gnd wire along the bottom of the diagram and 5V across the top.
The layout should not have diagonal wires.
Can you tell us your electronics, programming, arduino, hardware experience?
Tom.... :slight_smile:
TomGeorge:
Hehe sorry i will repair that, i make that instanly with fritzing so sorry. I first time using arduino uno , and newbie electronics, programming and hardware .
Yeah i forget about resistor in my LEDs RGB , but LED is using for indicator RFID is read for right CARD.
That shows WHERE the problem is. It says nothing about WHAT the problem is.
What IS the problem?
The resistor with the limit switch is useless. It is not pulling the pin UP to HIGH, or DOWN to LOW.
You appear to have pin D2 connected to pin D4, but the code appears to be trying to use them independently.
