Hello all,
I copied some code from the arduino playground that worked just fine to take the code from my rfid tag. But when i try to use the data to compare it to already stored data it does nothing.
Here is the code
// RFID reader for Arduino
// Wiring version by BARRAGAN
// Modified for Arudino by djmatic
int val = 0;
char code[10];
int bytesread = 0;
String comp;
Serial.begin(2400); // RFID reader SOUT pin connected to Serial RX pin at 2400bps
pinMode(2,OUTPUT); // Set digital pin 2 as OUTPUT to connect it to the RFID /ENABLE pin
digitalWrite(2, LOW); // Activate the RFID reader
if(Serial.available() > 0) { // if data available from reader
if((val = Serial.read()) == 10) { // check for header
bytesread = 0;
while(bytesread<10) { // read 10 digit code
if( Serial.available() > 0) {
val = Serial.read();
if((val == 10)||(val == 13)) { // if header or stop bytes before the 10 digit reading
break; // stop reading
code[bytesread] = val; // add the digit
bytesread++; // ready to read next digit
if(bytesread == 10) { // if 10 digit read is complete
Serial.println(code);
[center]THIS IS WHERE IT DOES NOT WORK[/center]
if (code == "3600290C6D") {
Serial.println("Welcome, Alan");
if (code == "0F03028718") {
Serial.println("Welcome, Oli");
bytesread = 0;
delay(500); // wait for a second
// extra stuff
// digitalWrite(2, HIGH); // deactivate RFID reader
everything compiles but even with the right card it does not print “Hello, Alan”
any ideas would be greatly appreciated, Thank you!
