Hi guys,
** I have problem with RFM12B 433MHz distance range issue, i am not using RFM12B library that is use for Arduino. Yes i am also working with arduino but with my RFM12B code and is working fine. What i found is RFM12B with Arduino library it works upto longer distance and high penetration through walls, even i dug a hole and put my unit inside, then also it was working and it worked upto 1 football ground. BUT with my code i am not getting that much range and penetration. Plz help me with this.**
I know it may be Bit Error Rate problem as Low bit rate less bandwidth and more range, i tried that but problem not solved. I am beginner to this understanding big complicated Arduino Library of RFM12B is tough. Thats why i had written my own code but its Performance is not like them.
So you have used a 'standard' Arduino library for the RFM12B, got it working and you get acceptable range from it.
But even though this library is working, its difficult to understand, so you wrote your own library and its not working well ?
Why dont you just use the 'standard' Library for the RFM12B and accept you dont understand the detail of how the device is setup ?
