RGB Code not working.
Hi, Im wanting to change the colour of an RGB LED. To do this I am using the FSR (Force sensitive resistor), I have the arduino reading the FSR pressure but its not changing the colour of the RGB.
Any help would be appreciated.
Thanks
 * This script does the following:
 * 1. Gets analog sensor input from a touch sensor
 * 2. Processes sensor data in a four state machine
 * 3. Adjusts an RGB LED color based on toouch sensor pressure using PWM
 * Written by: Jacek Spiewla (jacekspi@umich.edu)
 * Date Created:   2/23/2009
 * Date Modified:  3/17/2009
//Setup all pins
int sensPin = 2;    // set the touch sensor (analog) input pin on Arduino
int redPin = 11;    // set the PWM (analog) output pin on Arduino controlling the red anode
int grnPin = 9;        // set the PWM (analog) output pin on Arduino controlling the green anode
int bluPin = 10;    // set the PWM (analog) output pin on Arduino controlling the blue anode
//Setup all initial values
int val = 0;            // initial value for touch sensor input
int state = 1;        // initial machine state
//Initialize variables
int redVal;         // pulse width variable for red anode
int grnVal;         // pulse width variable for green anode
int bluVal;        // pulse width variable for blue anode
  pinMode(redPin, OUTPUT);   // set the LED pins as output
  pinMode(grnPin, OUTPUT);
  pinMode(bluPin, OUTPUT);
  val = analogRead(sensPin);           // read touch sensor values
  Serial.println(val);
  if (state == 1) {sleep();}        // turn off LED
  else if (state == 2) {redIn();}    // fade in red color
  else if (state == 3) {grnIn();}    // fade in green color
  else if (state == 4) {bluIn();}    // fade in blue color
void sleep() {
  alloff();                                  // turn off LED
  if (val > 20 && val <= 500)  {state = 2;}   // test for low pressure
  if (val > 500 && val <= 850) {state = 3;}   // test for medium pressure
  if (val > 850) {state = 4;}              // test for high pressure
void redIn() {                  // function to fade in red color and transition to other states
  grnVal = 0;
  analogWrite(grnPin, grnVal);  // turn off green in case the last state was green
  if (redVal == 255) {            // if red is at maximum, continue to light it up
    analogWrite(redPin, redVal);
  } else {                    // else fade in the red color
    redVal ++;
  if (val < 20) {state = 1;}    // turn off the LED if no pressure detected
  if (val > 500) {state = 3;}   // fade in green if pressure has increased
void grnIn() {                  // function to fade in green color and transition to other states
  redVal = 0;
  bluVal = 0;
  analogWrite(redPin, redVal);    // turn off red in case the last state was blue
  analogWrite(bluPin, bluVal);  // turn off blue in case the last state was blue
  if (grnVal == 255) {            // if green is at maximum, continue to light it up
  } else {                    // else fade in the green color
    grnVal ++;
  if (val <= 500) {state = 2;}    // fade in red if pressure has decrease
  if (val >= 850) {state = 4;}    // fade in blue if pressure has increased
void bluIn() {                  // function to fade in blue color and transition to other states
  grnVal = 0;
  if (bluVal == 255) {            // if blue is at maximum, continue to light it up
  } else {                    // else fade in the blue color
    bluVal ++;
  if (val <= 850) {state = 3;}    // fade in green if pressure has decreased
void alloff() { // function to turn off the LED
  redVal = 0;
  grnVal = 0;
  bluVal = 0;
Moderator edit: Please use tags when posting code.
Your setting of state is inconsistent.
sleep() sets state to 1, 2, or 3. redIn() might set it to 1 or 3. grnIn() might set it to 2 or 4. bluIn() might set it to 3.
Serial.print() or state in each pass through loop will be necessary. Not jerking state around in all the functions will probably be necessary, too.
NEED CODE
Thanks
Don't you already have a thread for this? http://arduino.cc/forum/index.php/topic,101599.0.html
Topics merged: @OP: Please don't post the same question multiple times - it wastes time.
It's not necessary to shout 'NEED HELP'. You probably wouldn't be posting if you didn't need help. It's also not really a good idea to keep posting the same question all over the forums.
t’s also not really a good idea to keep posting the same question all over the forums.
It’s actually a really bad idea.
@OP: Don’t do it - no more warnings.
