RGB Color Picker- One pot affects the others
Hey everyone. I created an RGB color picker that uses three potentiometers to control the amount of R, G, and B in an RGB LED. This circuit and code worked a while ago, but now, when I rotate one potentiometer, it somehow changes the others. The R, G, and B values seem to be jumping as well. I have each potentiometer connected to a different analog pin on the arduino. I have no idea what to do and I have to demonstrate this circuit soon in an interview.
Any help would be greatly appreciated.
Here is a video of what I'm talking about if it is still hard to visualize: https://drive.google.com/file/d/1DuxETy9RCZuzVLbNPQTu1U9NFUKBQAEl/view?usp=sharing
Here is a picture of my circuit: IMG_1647.JPG - Google Drive
Here is my code:
#include <LiquidCrystal.h>                 //Include the LCD library
LiquidCrystal lcd(7, 8, 10, 11, 12, 13);    //Set up LCD
#define rPot 2                         //Initialize Pot ports
#define gPot 1
#define bPot 0
#define rLED 6                          //Initialize RGB LED ports
#define gLED 5
#define bLED 3
  pinMode(rPot, INPUT);                    //Set Pots as inputs
  pinMode(gPot, INPUT);
  pinMode(bPot, INPUT);
  pinMode(rLED, OUTPUT);                   //Set LEDs as outputs
  pinMode(gLED, OUTPUT);
  pinMode(bLED, OUTPUT);
  analogWrite(9,50);                      //Set LCD contrast to 50 (in order to eliminate the use of a pot to control contrast)
  lcd.begin(16,2);                        //Set up LCD dimensions
  int r=map(analogRead(rPot), 0, 1023, 0, 255);      //Set r to pot value (/(1023/255) to match the pot range of 1023 to the LED's of 255)
  int g=map(analogRead(gPot), 0, 1023, 0, 255);       //Do the same with g
  int b=map(analogRead(bPot), 0, 1023, 0, 255);       //Do the same with b
  setColor(r, g, b);                       //Set the color of the LED to r, g, and b
  lcd.clear();                             //Clear the LCD
  printRGB(r, g, b);                       //Print the RGB value on the LCD
  printHex(r, g, b);                       //Print the HEX value on the LCD
  delay(30);                              //Delay for 30 milliseconds in order to eliminate of the "strobe light" effect on LCD
void setColor(int r, int g, int b){
  analogWrite(rLED, r);                    //Set R LED value to r
  analogWrite(gLED, g);                    //Same with G
  analogWrite(bLED, b);                    //Same with B
void printRGB(int r, int g, int b){
  String strR = String(r);                   //Set strR to string of r
  String strG = String(g);                   //Set strG to string of g
  String strB = String(b);                   //Set strB to string of b
  String rgb="("+strR+","+strG+","+strB+")";     //Compile strR, strG, and strB with parenthesis at the ends and commas in between each value
  lcd.setCursor(0,0);                      //Print at column 1, row 1
  lcd.print("RGB");                        //Print RGB to indicate that it is the rgb value
  lcd.print(rgb);                          //Print the value
void printHex(int r, int g, int b){
  String strR = String(r, HEX);              //Convert r to hex and set the string of it to strR
  String strG = String(g, HEX);              //Convert g to hex and set the string of it to strG
  String strB = String(b, HEX);              //Convert b to hex and set the string of it to strB
  strR.toUpperCase();                        //Capitalize strR
  strG.toUpperCase();                        //Same with strG
  strB.toUpperCase();                        //Same with strB
  if (strR.length()==1)                   //Ensures that strR is two characters instead of one
    strR=strR+strR;
  if (strG.length()==1)                    //Same with strG
    strG=strG+strG;
  if (strB.length()==1)                   //Same with strB
    strB=strB+strB;
  String hex=strR+strG+strB;                     //Compile strR, strG, and strB to form hex code
  lcd.setCursor(0,1);                      //Print at column 1, row 2
  lcd.print("Hex:");                       //Print "Hex:" to indicate that it is the hex value
  lcd.print(hex);
Crosstalk between A/D channels can be caused by (too) high pot resistance values.
10kB (10k linear is recommended).
Or bad breadboard contact an/or sharing 5volt/ground with other parts of the circuit.
Give the pots their own (not shared) 5volt and ground connection to the Arduino.
If nothing else helps, then do a double read on the analogue inputs.
Only the second more stable reading will then be used.
could be
int r = (analogRead(rPot); // dummy reading
int r = (analogRead(rPot) >> 2); // real one, and converted to 8-bit (0-255)
Leo..
