RGB Halo Project Issues
I have created some code that will sort the inputted numbers into a min mid and max variable. However, the problem is whenever the inputted values are the same. The program does not recognize this.
int red;
int green;
int blue;
int mMin;
int mMid;
int mMax;
void minMidMax()
  mMax = green;
  if(red > mMax)
    mMax = red;
  if(blue>mMax)
    mMax = blue;
  mMin = green;
  if(red<mMin)
    mMin = red;
  if(blue<mMin)
    mMin = blue;
  if(green>mMin&&green<mMax)
    mMid = green;
  if(red>mMin&&red<mMax)
    mMid = red;
  if(blue>mMin&&blue<mMax)
    mMid = blue;
  Serial.print("Red: ");
  while(Serial.available()==0)
  red = Serial.parseInt();
  Serial.println(red);
  Serial.print("Green: ");
  green = Serial.parseInt();
  Serial.println(green);
  Serial.print("Blue: ");
  blue = Serial.parseInt();
  Serial.println(blue);
  minMidMax();
  Serial.println(mMin);
  Serial.println(mMid);
  Serial.println(mMax);
Before determining mMid, you must also set mMid = green - as with min and max.
Is this a well camouflaged duplicate of
Finding the minimum, middle and maximum values?
