My code is bad and I should feel bad :~
Sometimes on low temps the red shows up, same with high temps - the blue shows up.
Does any one mind doing a little optimization or helping me find what causes the issue?
#include <OneWire.h>
#include <DallasTemperature.h>
const int sensPin = 9;
const int redPin = 3;
const int greenPin = 5;
const int bluePin = 6;
OneWire oneWire(sensPin);
DallasTemperature sensors(&oneWire);
DeviceAddress insideThermometer = { 0x28, 0xE7, 0x19, 0x74, 0x03, 0x00, 0x00, 0x7F };
// initialize serial:
// make the pins outputs:
sensors.begin();
sensors.setResolution(insideThermometer, 10);
pinMode(redPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(bluePin, OUTPUT);
analogWrite(bluePin, 255);
analogWrite(redPin, 255);
analogWrite(greenPin, 255);
sensors.requestTemperatures();
float temp = sensors.getTempC(insideThermometer);
int blue = 255 - (map(temp, 31, 0, 0, 63) * 4);
int green = 255 - (map(temp, 34, 26, 0, 100) * 2);
int red = 255 - (map(temp, 50, 31, 0, 63) * 4);
analogWrite(bluePin, blue);
analogWrite(greenPin, green);
analogWrite(redPin, red);
Serial.print("Inside temperature is: ");
Serial.print(temp);
Serial.print("\n\r");
For the mathematically inclined, here's the whole function
long map(long x, long in_min, long in_max, long out_min, long out_max)
return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
Judging by your calls to map, the result may not be what you wanted. shouldn't it be like this?
int blue = 255 - (map(temp, 0,31, 0, 63) * 4);
int green = 255 - (map(temp, 26, 34, 0, 100) * 2);
int red = 255 - (map(temp, 31,50, 0, 63) * 4);
Also, imagine the temperature is 20. your green will be -175. Which, converted to unsigned char to write in the PWM register will be a bit different than what you expect.
Why don't you adjust the temperature to the PWM directly?
map(temp, green_low, green_high, 0, 255); //or some other PWM values that do what you want...
The led is an anode not a cathode, that is why the max is min and min is max...
