RGB LED Circuit - transfer to protoshield query
Hi all,
I have an RBG LED circuit - the LED’s are controlled by a proximity sensor (the MaxSonar XL EZ0). The circuit is all up and running fine on breadboard, and I want to transfer it to a shield that sits on top of the arduino. The circuit is shown in the attached photos.
In fact, the circuit is shown as a layout sheet (attached), with the proximity sensor added to 3.3.V, ground and a digital pin (7):
I’ve drawn up what I think I need to do to transfer it to the shield (attached). Can any experienced users tell me if this translates correctly?
And am I right in assuming I can solder across contacts on the shield to make the paths similar to those on the breadboard?
Thanks in advance
Rob
Layout looks good.
Yes you can solder across pads.
