RGB LED code problem
Circuit works when you test each pin and RGB LED lead.
But in my loop, as soon as I add an additional lead to manipulate,
none of the code works.
const int redPin = 7;
const int greenPin = 6;
const int bluePin = 5;
pinMode(redPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(bluePin, OUTPUT);
//Lights up the redPin without issue
Serial.println("Writing to redPin");
analogWrite(redPin, 254);
analogWrite(redPin, 0);
/* As soon as I add another pin to the mix,
If I comment out the redPin and the bluePin and just use the greenPin, it works fine.
Serial.println("Writing to greenPin");
analogWrite(greenPin, 254);
analogWrite(greenPin, 0);
//Same with the bluePin, works fine on its own, but doesn't work when another pin is added
Serial.println("Writing to bluePin");
analogWrite(bluePin, 254);
analogWrite(bluePin, 0);
You're not using the same pins as the tutorial. Pin 7 on an Uno doesn't support PWM. What board are you using?
aarg:
I am using an Elegoo Mega 2560. Pins 7, 6, and 5 are PWM~
Can you please post a clear photograph of your wiring layout?
TheMemberFormerlyKnownAsAWOL:
Your code doesn't match the schematic.
You are correct. Thank you. I had all of the leads on the RBG going to ground.
