Good day all. This is first post here, even though I have gained quite a lot from the contributions in this forum. Here is the problem, I am working on a project where the aim is to control an RGB LED to display the color (even if roughly) of an image placed in front of a JPEG Color Camera TTL Interface (the camera here: http://www.sparkfun.com/products/10061). I am a beginning programmers, so this code might be look a bit sloppy (pardon me for that). The basic aim of this code is just to take a pixel from the data coming from the camera after every few seconds, feed it to the digital pins where the RGB LED are and discard the rest. The code used three subroutines (Camera, getdata and process) given at the end of the void loop. The code does not seem to work the way I expected. And I have been on this for three weeks. Sometimes the RGB LED is on produces a color different from what is placed in front of the camera. Sometimes, there is no reponse at al. I can’t seem to be able to figure out the problem.
Firstly, I would be grateful if I can be helped on the possibility of achieving the aim of the project.Secondly, any help on how to improve the code or alternative means would greatly appreciated. By the way, I have used color sensor to do the same, but since color sensors are of limited range, the camera is preferred. Thank you all.
int sync[] = {0xaa,0x0d,0x00,0x00,0x00,0x00}; // Sync command
int initial[] = {0xaa,0x01,0x00,0x06,0x01,0x03}; // initial command
int ack[] = {0xaa,0x0e,0xff,0x00,0x00,0x00}; // ack command
int snap[] = {0xaa,0x05,0x01,0x00,0x00,0x00}; // snap command
int getpic[] = {0xaa,0x04,0x02,0x00,0x00,0x00}; // get the snaped pic comma nd
int reset[] = {0xaa,0x08,0x01,0x00,0x00,0xff}; // reset the camera (special)
byte incomingByte[24]; // reserved bytes for incoming data
//The boolean variables below are just flags for initial, sync, snap,getpic and reset
boolean Initial = 0;
boolean Sync = 0;
boolean Snap = 0;
boolean Getpic = 0;
boolean Reset = 0;
//Loop counters
int i = 0;
int n = 0;
int k = 0;
int R ,G , B; // out put R G and B value, in int, 0-255.
int G1,G2; // used when calculating G VALUE
Serial.begin (57600);//set serial bund rate = 57600
pinMode(9, OUTPUT);// pin 9 is the positive pole of the LED
pinMode(10, OUTPUT);//R PWM output
pinMode(11, OUTPUT);//G PWM output
pinMode(12, OUTPUT);//B PWM output
pinMode(2, OUTPUT);//
digitalWrite(2, HIGH);
/***************SYNC**************/
while (!Sync)//check whether sync had beed done
Camera(sync); //call subroutine (Camera) and send command sync
delay(200) ;
if (Serial.available())
n=12; //answer for sync is 12byte.
getdata(); //call subroutine (getdata). Get the ansewer which is stored in incomingByte.
if(incomingByte[0]==0xaa && incomingByte[1]== 0x0e) //if the command have been received, camera will return an answer begging with 0xaa, 0x0e
{Sync = 1;}
//Now that Sync is done, send an ack command to camera
Camera(ack);
/***************INITIAL************************/
while (!Initial)
Camera(initial);
delay(200) ;
n=6;
getdata();
{Initial = 1;}
else {Initial = 0;}
/******GETPICTURE************************/
while (!Getpic)
Camera(getpic);
n=24;
//Take only 24 byte data. data 1-12 is camera's responding for the getpicture command,*****//
//***data 13-24 is the data of first pixels **/
getdata();
Getpic = 1;
//call subroutine (process).
process(18);
{Snap=0;Getpic = 0;}
delay(5000) ;
Camera(ack);
/******RESET************************/
while (!Reset)
Camera(reset);
delay(200) ;
n=12;
getdata();
{Reset = 1;}
Camera(ack);
digitalWrite(12, LOW);
Initial = 0;
Sync = 0;
Snap = 0;
Getpic = 0;
Reset = 0;
/******************Subrotine1-->(Camera)*************/
void Camera(int wanttosend[6])//subrotine for sending an command to camera.
for(int i= 0;i<6;i++)
{Serial.write(wanttosend[i]);} //send byte by byte}
/****************Subrotine2-->(getdata)*****************/
void getdata()// this is to get data from the serial prot
int k = 0;
while (Serial.available())// get data continually until all data had been got
for( i=Serial.available();i<n; i--){
incomingByte[k] = Serial.read();//data are stored in incomingByte[]
k++;
delay (10);
Serial.flush();//fulsh the serial port to insure the income buf is clear
/***********************Subrotine3--> (process)*********/
void process(int j)//calculate the RGB FROM DATA.
//data format is RGB565, ie. 5bit R value , 6 bit G value and then 5 bit B value.
Serial.println(incomingByte[j],HEX);
Serial.println(incomingByte[j+1],HEX);
R = incomingByte[j]>>3;
R = R*8;//for R, the high byte right shift fro 3 bits . and times 8 to make is ranges from 0 - 255
B = incomingByte[j+1];
bitClear(B,7);
bitClear(B,6);
bitClear(B,5);
B =B*8;//for B , the low byte's lower 5bits. so clear the higher 3 bits and times 8 to make it ranges from 0 -255
G1 = incomingByte[j]<<5;
G1 = incomingByte[j+1]>>5;
G2 = incomingByte[j+1]>>5;
G = (G1*8+G2)*4;//the lower 3 bit of incomingByte[12] is the G value's higher 3 bits; the higher 3 bit of incomingBytr[13] is the lower 3 bit.
digitalWrite(12, HIGH);
analogWrite(9, 255-R);
analogWrite(10, 255-G);
analogWrite(11, 255-B); //generate color display from RGB Value.
