Hello everyone i am having some troubles to use the IRremote library with my project.
I want to control an rgb led with my infrared remote. The behavior i expect from this project is simple, i push to one control button to trigger the “fade” mode or push to another button to instantly change mode to “flash”.
So i create two functions, one with all colors fading and one where all colors flash one after the other.
But here is the problem, i power up my arduino mega i push to the button for start the “flash” mode and after a while i push the button for “fade” mode and i have to wait till the previous mode finish and then i get the “fade” mode.
I’m not having a lot of experience with interrupts or timer but i guess the problem in my code is that i use to match the delay function, since the IRremote library use’s the timer2 in pin 9 for new incoming values from the infrared port.
If you have any suggestion to help me improve my project,
This is my code :
#include <IRremote.h>
#include <IRremoteInt.h>
int led[3] = {
5, 6, 7}; // the pins that the LEDs is attached to 5 is red, 6 is green, 7 is blue
int brightness = 0; // how bright the LED is
int fadeAmount = 5; // how many points to fade the LED by
int fadeDelay = 30;
unsigned long command = 0;
int RECV_PIN = 9;
IRrecv irrecv(RECV_PIN);
decode_results results;
// the setup routine runs once when you press reset:
irrecv.enableIRIn();
// declare pin 5, 6, 7 to be an output:
for(int i=0;i<3;i++){
pinMode(led[i], OUTPUT);
// the loop routine runs over and over again forever:
if (irrecv.decode(&results)) {
if(results.value!=0xFFFFFFFF)
command = results.value;
Serial.println(command, HEX);
irrecv.resume(); // Receive the next value
switch(command){
case 0x2FDC837:
fadeRgb(led, brightness, fadeAmount, fadeDelay);
case 0x2FD8877:
flashRgb(led);
default:
void fadeRgb(int *led, int brightness, int fadeAmount, int fadeDelay) {
// RED
for(brightness=0; brightness<=256; brightness+=fadeAmount) {
analogWrite(led[0], brightness);
delay(fadeDelay);
// YELLOW
analogWrite(led[1], brightness);
delay(fadeDelay);
// GREEN
for(brightness=255; brightness>=0; brightness-=fadeAmount) {
delay(fadeDelay);
// CYAN
for(brightness=0; brightness<=255; brightness+=fadeAmount) {
analogWrite(led[2], brightness);
delay(fadeDelay);
// BLUE
delay(fadeDelay);
// MAGENTA
delay(fadeDelay);
// WHITE
delay(fadeDelay);
// ALL COLORS FADE
analogWrite(led[i], brightness);
delay(fadeDelay);
void flashRgb(int *led){
// RED
digitalWrite(led[0], HIGH);
digitalWrite(led[0], LOW);
// YELLOW
digitalWrite(led[1], HIGH);
digitalWrite(led[1], LOW);
// GREEN
// CYAN
digitalWrite(led[2], HIGH);
digitalWrite(led[2], LOW);
// BLUE
// MAGENTA
// WHITE
