RGB LED Controlled with Nano and Accelerometer
Hey all, this is my first time posting to the community. I am a mechanical engineer with a little bit of college training in microcontrollers, so I apologize in advance if I make silly mistakes. Please let me know if this is the wrong board, or if I make any faux pas. On to the project!
This project is for a cosplay wizard's staff. I have a high intensity RGB LED that I am controlling with a Nano and an accelerometer. The idea is that at rest, the LED will show low intensity white, then on change in acceleration (jerk) in the x, y, or z direction, the strength of the red, blue, or green will increase respectively, then slowly fall back to rest value. I have some code written (follows) that works, and I can currently get the desired effect with a cheapo RGB LED.
The questions:
  1. The code I wrote works, but I don't delude myself in to thinking I'm a coding wiz; do you see anything in there that I can change to make it more efficient/elegant?
  2. I would like to use a higher intensity RGB LED (parts to follow). Do I need to do anything to protect the mosfet or the LED from burning out? I have attached an illustration of my prototype layout to this post.
The parts:
Microcontroller: Arduino Nano
Accelerometer: LSM9DS1
RGB LED: SMT LED 5050
MOSFET: N-channel power MOSFET 30V/60A
Power: 2200mAh 5V/1A
The Code:
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_LSM9DS1.h>
#include <Adafruit_Sensor.h>  // not used in this demo but required!
// i2c
Adafruit_LSM9DS1 lsm = Adafruit_LSM9DS1();
#define LSM9DS1_SCK A5
#define LSM9DS1_MISO 12
#define LSM9DS1_MOSI A4
#define LSM9DS1_XGCS 6
#define LSM9DS1_MCS 5
// You can also use software SPI
//Adafruit_LSM9DS1 lsm = Adafruit_LSM9DS1(LSM9DS1_SCK, LSM9DS1_MISO, LSM9DS1_MOSI, LSM9DS1_XGCS, LSM9DS1_MCS);
// Or hardware SPI! In this case, only CS pins are passed in
//Adafruit_LSM9DS1 lsm = Adafruit_LSM9DS1(LSM9DS1_XGCS, LSM9DS1_MCS);
//Define LED Pins
int redPin = 9;
int greenPin = 10;
int bluePin = 11;
//Set Resting Value for colors
int redRest = 240;
int blueRest = 240;
int greenRest = 240;
//Value to be written to LED Pins
int redVal = 0;
int blueVal = 0;
int greenVal = 0;
//Modifier for LED Values
float redAccel = 0;
float blueAccel = 0;
float greenAccel = 0;
void setupSensor()
  // 1.) Set the accelerometer range
    lsm.setupAccel(lsm.LSM9DS1_ACCELRANGE_2G);
//Required for Sensor
  lsm.begin();
  setupSensor();
//Initialize LED PINS as OUTPUT
  pinMode(redPin, OUTPUT);
  pinMode(bluePin, OUTPUT);
  pinMode(greenPin, OUTPUT);
//Start at LED REST value
  analogWrite(redPin, redRest);
  analogWrite(bluePin, blueRest);
  analogWrite(greenPin, greenRest);
//Call function to calculate average Jerk
  jerk(&redAccel, &blueAccel, &greenAccel);
//Attenuate Red rest noise, change the value to be written (brightens LED)
  if (redAccel > 1)
    redVal -=redAccel;
//Don't let the value go negative
  if (redVal <= 0)
    redVal = 0;
//Repeat for Blue and Green
  if (blueAccel > 2)
    blueVal -=blueAccel;
  if (blueVal <= 0)
    blueVal = 0;
  if (greenAccel > 2)
    greenVal -=greenAccel;
  if (greenVal <= 0)
    greenVal = 0;
//Write the new value to the LED
  analogWrite(redPin, redVal);
  analogWrite(bluePin, blueVal);
  analogWrite(greenPin, greenVal);
//Fade the LED back to Rest state
  if (redVal < redRest)
    redVal +=10;
  if (blueVal < blueRest)
    blueVal +=10;
  if (greenVal < greenRest)
    greenVal +=10;
The Function:
void jerk(float* xAve, float* yAve, float* zAve)
//6 value array for holding acceleration readings
  float xAccel[7];
  float yAccel[7];
  float zAccel[7];
//Initalize the values that will be passed back as 0
  float xAverage = 0;
  float yAverage = 0;
  float zAverage = 0;
//Get the new values for 6 acceleration events
  for (int i = 0; i < 6; i++)
        lsm.read();  /* ask it to read in the data */
         /* Get a new sensor event */
        sensors_event_t a, m, g, temp;
         lsm.getEvent(&a, &m, &g, &temp);
      xAccel[i] = a.acceleration.x;
      yAccel[i] = a.acceleration.y;
      zAccel[i] = a.acceleration.z;
      delay(5);
//Calculate the jerk
  for (int n = 0; n < 5; n++)
      xAverage += (xAccel[n]-xAccel[n+1])/.1;
      yAverage += (yAccel[n]-yAccel[n+1])/.1;
      zAverage += (zAccel[n]-zAccel[n+1])/.1;
//Take the average of the jerk and pass it back to Loop
  *xAve = (xAverage/6);
    if (xAverage < 0 )
      *xAve = xAverage*-1;
  *yAve = (yAverage/6);
    if (yAverage < 0 )
      *yAve = yAverage*-1;
  *zAve = (zAverage/6);
    if (zAverage < 0 )
      *zAve = zAverage*-1;
Thanks again for any help/suggestions/insight!
High power leds should have a constant current circuit, not rely on a current limiting resistor.
Learn how to time things with millis() and unsigned integer variables. There are any tutorials on the lesson, such as the 1st Nick Gammon (not me) tutorial I list in my signature space below. It is key to "cooperative multitasking" on Arduinos which could also be described as "virtual parallel processing" on Arduinos. When your code blocks inside of loop() all get a chance to run in every pass through loop() and none of them hogs up cycles (aka blocks execution) virtual PP gets real without an OS forcing it.
You could use a piezo disk to detect the staff butt being thumped on the floor/ground or other things, even to approximate how hard it hit.
