RGB LED Controller code question
Hello. I'm building a RGB controller using an Arduino. It will have several buttons and sliding pots for effect control. I hooked up a RGB LED on pins 9,10 and 11 and 3 pushbuttons to turn them on and off. So far it is working, here is the code:
  Set a state of a variable when you press a pushbutton ( the
  button went from off to on ).
  created 01-12-2009 by kasperkamperman.com
  based on example 'State change detection' by Tom Igoe
  RGB LED on-off
const int buttonRed   = 2;     // the pin that the Red pushbutton is attached to
const int buttonGreen = 3;     // the pin that the Green pushbutton is attached to
const int buttonBlue  = 4;     // the pin that the Blue pushbutton is attached to
const int Red         = 9;     // the pin that the Red LED is attached to
const int Green       = 10;    // the pin that the Green LED is attached to
const int Blue        = 11;    // the pin that the Blue LED is attached to
int RedbuttonState      = 0;     // current state of the Red button
int lastRedButtonState  = 0;     // previous state of the Red button
int RedledState         = 0;     // remember current Red LED state
int BluebuttonState     = 0;     // current state of the blue button
int lastBlueButtonState = 0;     // previous state of the blue button
int BlueledState        = 0;     // remember current blue LED state
int GreenbuttonState     = 0;    // current state of the green button
int lastGreenButtonState = 0;    // previous state of the green button
int GreenledState        = 0;    // remember current green LED state
  pinMode(buttonRed, INPUT);      // initialize the button pin as a input
  pinMode(buttonGreen, INPUT);    // initialize the button pin as a input
  pinMode(buttonBlue, INPUT);     // initialize the button pin as a input
  pinMode(Red, OUTPUT);           // initialize the RED LED pin as a output
  pinMode(Green, OUTPUT);         // initialize the GREEN LED pin as a output
  pinMode(Blue, OUTPUT);          // initialize the BLUE LED pin as a output
  // read the pushbutton input pin
  RedbuttonState = digitalRead(buttonRed);
  GreenbuttonState = digitalRead(buttonGreen);
  BluebuttonState = digitalRead(buttonBlue);
  // check if the button is pressed or released
  // by comparing the buttonState to its previous state
  if (RedbuttonState != lastRedButtonState) {
  // change the state of the led when someone pressed the button
    if (RedbuttonState == 1) {
      if(RedledState==1) RedledState=0;
      else            RedledState=1;
    // remember the current state of the button
    lastRedButtonState = RedbuttonState;
  if  (GreenbuttonState != lastGreenButtonState) {
    if (GreenbuttonState == 1) {
      if(GreenledState==1) GreenledState=0;
      else GreenledState=1;
  lastGreenButtonState = GreenbuttonState;
    if  (BluebuttonState != lastBlueButtonState) {
    if (BluebuttonState == 1) {
      if(BlueledState==1) BlueledState=0;
      else BlueledState=1;
  lastBlueButtonState = BluebuttonState;
  // turns LED on if the ledState=1 or off if the ledState=0
  digitalWrite(Red, RedledState);
  digitalWrite(Green, GreenledState);
  digitalWrite(Blue, BlueledState);
  // adding a small delay prevents reading the buttonState too fast
  // ( debouncing )
  delay(20);
Next step is add 3 more buttons, each of them will light a secondary color (cyan, yellow, magenta), that means each of this new buttons must turn 2 LEDs on and off at the same time. I can get those colors already by simply by pushing 2 buttons and leaving them on, but I really need another button to make the color easier to spot on the controller. How can I accomplish that ? I'm not really good with code. Thanks in adv.
You can toggle states more easily. Instead of:
      else            RedledState=1;
You can do:
       RedledState = !RedledState;   // toggle RedledState
As for cyan, etc. you have have states for them as well (like R, G, B). Then when you go to change the LEDs themselves, something like:
  digitalWrite(Green, GreenledState || CyanledState);
  digitalWrite(Blue, BlueledState || CyanledState);
In other words, you turn on green if either green or cyan is wanted.
Great! Thank you. I got it working with buttons for red, green, blue, yellow, magenta, cyan, black and white! Here is the code:
const int buttonYellow  = 5;  // the pin that the Yellow pushbutton is attached to
const int buttonMagenta = 6;  // the pin that the Magenta pushbutton is attached to
const int buttonCyan    = 7;  // the pin that the Cyan pushbutton is attached to
const int buttonWhite   = 8;  // the pin that the White pushbutton is attached to
const int buttonBlack   = 13; // the pin that the Black pushbutton is attached to
const int buttonEFFECT1 = 1;  // the pin that the EFFECT1 pushbutton is attached to
const int chave   = 12;   // switch, "forcing" color
const int Red     = 11;   // the pin that the Red LED is attached to
const int Green   = 9;    // the pin that the Green LED is attached to
const int Blue    = 10;   // the pin that the Blue LED is attached to
int redButtonState      = LOW;    // current state of the Red button
int blueButtonState     = LOW;    // current state of the Blue button
int greenButtonState    = LOW;    // current state of the Green button
int yellowButtonState   = LOW;    // current state of the Yellow button
int magentaButtonState  = LOW;    // current state of the Magenta button
int cyanButtonState     = LOW;    // current state of the Cyan button
int whiteButtonState    = LOW;    // current state of the White button
int blackButtonState    = LOW;    // current state of the Black button
int EFFECT1ButtonState  = LOW;    // current state of the EFFECT1 button
  pinMode(buttonRed, INPUT);      // initialize the button pin as an input
  pinMode(buttonGreen, INPUT);    // initialize the button pin as an input
  pinMode(buttonBlue, INPUT);     // initialize the button pin as an input
  pinMode(buttonYellow, INPUT);   // initialize the button pin as an input
  pinMode(buttonMagenta, INPUT);  // initialize the button pin as an input
  pinMode(buttonCyan, INPUT);     // initialize the button pin as an input
  pinMode(buttonWhite, INPUT);    // initialize the button pin as an input
  pinMode(buttonBlack, INPUT);    // initialize the button pin as an input
  pinMode(buttonEFFECT1, INPUT);  // initialize the button pin as an input
  pinMode(chave, INPUT);          // initialize the switch pin as an input
  pinMode(Red, OUTPUT);           // initialize the RED LED pin as an output
  pinMode(Green, OUTPUT);         // initialize the GREEN LED pin as an output
  pinMode(Blue, OUTPUT);          // initialize the BLUE LED pin as an output
  if (digitalRead(buttonRed) == HIGH) {
    redButtonState = !redButtonState;
    while (digitalRead(buttonRed) == HIGH) {}
    if (digitalRead(chave)) {
      redButtonState = HIGH;
  if (digitalRead(buttonGreen) == HIGH) {
    greenButtonState = !greenButtonState;
    while (digitalRead(buttonGreen) == HIGH) {}
      greenButtonState = HIGH;
  if (digitalRead(buttonBlue) == HIGH) {
    blueButtonState = !blueButtonState;
    while (digitalRead(buttonBlue) == HIGH) {}
      blueButtonState = HIGH;
  if (digitalRead(buttonYellow) == HIGH) {
    while (digitalRead(buttonYellow) == HIGH) {}
  if (digitalRead(buttonMagenta) == HIGH) {
    while (digitalRead(buttonMagenta) == HIGH) {}
    if (digitalRead(buttonCyan) == HIGH) {
    while (digitalRead(buttonCyan) == HIGH) {}
    if (digitalRead(buttonWhite) == HIGH) {
    while (digitalRead(buttonWhite) == HIGH) {}
  if (digitalRead(buttonBlack) == HIGH) {
    while (digitalRead(buttonBlack) == HIGH) {}
  digitalWrite(Red, redButtonState);
  digitalWrite(Green, greenButtonState);
  digitalWrite(Blue, blueButtonState);
As you can see I've added a EFFECT1 button, that will strobe the red LED, but I need help implementing that. I know I have to use millis and create some sort of interval for the effect to happen, but that's pretty much it,.. any help would be great, thanks in advance,
Anyone ?
Did you try anything? Something like this could work:
Instead of:
Have:
if ((millis () & 0x7F) < 63)
  digitalWrite(10, HIGH);
  digitalWrite(10, LOW);
That forces the Red LED off if the low-order 7 bits of the millis time are < 63. Effectively this makes the LED go off every 64ms seconds and then on for 64ms, giving a frequency of 7.8Hz.
You can play with the figures to give different rates of flashing.
