RGB LED Matrix - No clock
Hello, I am trying to run the 64x32 RGB LED Matrix example (testShapes_32x64) on an Arduino Uno with LED Matrix Shield, and it does not appear to be clocking.
When I probe the ouputs with my scope, I see activity on the RGB pins and on ADDR D. There is no activity on CLK, OE, LAT, or ADDR A,B,C.
I see the same behavior with and without the Shield installed, so it does not appear to be a wiring issue with the Shield or LED Matrix.
I also tried the scrolltext_16x32 example and saw the same results, except that there is no activity on any of the ADDR lines, which makes sense because ADDR D is only used for larger panels.
This Uno has worked fine for other recent projects.
I am using version 1.8.12 of the Arduino tools, with version 1.1.3 of the RGB matrix Panel library.
Any ideas of what to try next?
Thanks,
David
Because the pins aren’t shaking, either the source data is incorrect, or you code is missing something.
Once you get past this it’s probably worth looking at your parts & wiring.
After spending awhile picking apart the RGBMatrix code, I discovered that the larger panels are not supported by Uno. A Mega is required.
That’s half an answer....
The two chips have the same processing core, with different FLASH, RAM and EEPROM capacities.
If it compiles and fits in a UNO, it should run.
The pins will still toggle etc, you have a more fundamental problem to solve.
