I'll try to explain this. I'm using a attiny44 with 4 common anode RGB LED's. 3 pwm pins on the attiny44 are being used on common cathodes R,G and B pins. I'm having a problem with the code. I'm trying to have 10 "modes." The syncPin, or button is pressed, the counter is increased by one. When it goes through the mode 2 and 10 it skips over it with a small delay. The LED's flashes quickly. The other modes are fine, but I cannot get the modes 2 and 10 to work. Basically, I guess its only looping once through mode 2. Something is causing the counter to increase at the end of the loop for mode 2 and 10???
Any and all help would be greatly appreciated.
I'm sure I did not give some crucial information to the project...
ALRIGHT, Thanks!!!!
-Twiener
int redPin = 6;
int bluePin = 8;
int greenPin = 7;
int xButton = 3;
int aButton = 1;
int yButton = 2;
int bButton = 4;
int syncPin = A5;
unsigned int counter;
int sensorValue;
int firstCount = 250;
int secondCount = 250;
int thirdCount = 250;
int fourthCount =250;
 pinMode(redPin, OUTPUT);  // sets the redPin to be an output
 pinMode(greenPin, OUTPUT);  // sets the greenPin to be an output
 pinMode(bluePin, OUTPUT);  // sets the bluePin to be an output
 pinMode(yButton, OUTPUT);
 pinMode(aButton, OUTPUT);
 pinMode(bButton, OUTPUT);
 pinMode(xButton, OUTPUT);
 pinMode(syncPin, INPUT);
 int counter = 1;
 //change mode
 if (counter == 1)
  color(0, 0, 0); //    OFF
  digitalWrite(yButton, HIGH);
  digitalWrite(xButton, HIGH);
  digitalWrite(bButton, HIGH);
  digitalWrite(aButton, HIGH);
  delay(1);
 if (counter == 7)
  color(0, 255, 50); //alien green
  delay(1);
 if(counter == 8)
  color(255,51,153);          //pink
  delay(1);
 if(counter == 9)
  color(128,0,255);          //purple
  digitalWrite(aButton, HIGH);Â
  delay(1);
 if(counter == 5)
Â
  color(0,0,255);                             // dark blue
  delay(1);
 if(counter == 6)
Â
  color(0,255,255);       //light blue
  delay(1);
 if(counter == 4)
Â
  color(0,255,0);         //green
  delay(1);
 if(counter == 11 )
Â
  color(255,255,255);         //WHITE
  delay(1);
 if(counter == 3)
Â
 Â
  color(255,255,0);         //red
  delay(1);
 if(counter == 2)
Â
  Â
   color(255, 255, 0);
   delayMicroseconds(200);
  Â
   digitalWrite(yButton, LOW);
  Â
   color(0, 0 , 255 );
  Â
  Â
  Â
  Â
   digitalWrite(xButton, LOW);
     Â
   color(255, 0, 0);
  Â
  Â
  Â
  Â
   digitalWrite(bButton, LOW);
        Â
   color(0, 255, 0);
  Â
  Â
  Â
  Â
   digitalWrite(aButton, LOW);
   delay(1);
  Â
  Â
 if(firstCount > 0 && counter == 10)
Â
   color(255, 255, 0);         //first part
   delay(1);
   color(0, 0 , 255 );
   delay(1);
   color(255, 0, 0);
   delay(1);
   color(0, 255, 0);
   delay(1);
  Â
  firstCount--;
 if(secondCount > 0 && firstCount <= 0 && counter == 10)
   color(0, 255, 0);        // second part
   delay(1);
   color(255, 255, 0);
   delay(1);
   color(0, 0 , 255 );
   delay(1);
   color(255, 0, 0);
   delay(1);
  secondCount--;
 if(thirdCount > 0 && secondCount <= 0 && firstCount <= 0 && counter == 10)
   color(255, 0, 0);        // third part
   delay(1);
   color(0, 255, 0);
   delay(1);
   color(255, 255, 0);
   delay(1);
   color(0, 0 , 255 );
   delay(1);
  thirdCount--;
 if(fourthCount > 0 && thirdCount <= 0 && secondCount <= 0 && firstCount <= 0 && counter == 10)
   color(0, 0, 255);        // fourth part
   delay(1);
   color(255, 0, 0);
   delay(1);
   color(0, 255, 0);
   delay(1);
   color(255, 255, 0);
   delay(1);
  fourthCount--;
 if(fourthCount <=0 && counter == 10)
  firstCount = 250;
  secondCount = 250;
  thirdCount = 250;
  fourthCount = 250;
Â
  int sensorValue = analogRead(syncPin);
  float voltage = sensorValue * (5.0 / 1023.0);
  if(analogRead(sensorValue) < 5)
   delay(200);
   counter ++;
   delay(200);
//Reset count if over max mode number
  if(counter > 11)
   counter = 1;
} //end loop
void color(unsigned char red, unsigned char green, unsigned char blue)Â Â // the color generating function
 analogWrite(bluePin, 255-blue);
 analogWrite(greenPin, 255-green);
 analogWrite(redPin, 255-red);
