RGB LED not lighting up
Trying to vary each diode in an RGB LED in response to answers while also showing the whole spectrum l. I checked each circuit by connecting to the 5V supply instead of pins 9-10-11 (red-green-blue) respectively, and the LED lit up according to the designated color. Resistor values are 330ohms each.
Welcome to the forum.
What is your question? Hints on effective posting can be found in the "How to get the best out of this forum" post, linked at the head of every forum category.
Here's the code. Literally my first time coding. Thanks for any help.
YouCut_20230605_013630313
What is the question?
Please edit your post to post the code using code tags. Do not post pictures of code.
Take a few moments to explain what the code should do, and if there is a problem, what the code does instead.
Images of code are worthless. Please read the forum guidelines to see how to properly post code and some information on making a good post.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in a code block.
Please post a wiring diagram or schematic. Hand drawn, photographed and posted is fine. Include all pin names/numbers, components, their part numbers and/or values and power supplies.
My bad no wonder 4mb was the limit will take this post down sir.
Don't take it down, just proceed with the rules.
Can you also show how you have it wired with a schematic? It'll have to change based on whether you have common anode or common cathode LED's.
