RGB led project issues.
Hello all, I am currently working on a project with common anode RGB LEDs while trying to use my PWM ports as the ground to control the LEDs. I understand the concepts behind how this should work, I, however, haven't been able to find any information about what the maximum current a port on the Arduino can handle when being used as an input. Any clarification would be a wonderful help, Cheers.
40mA absolute max.
Nothing to do with Covid, though
@tryingmybesthere
Your topic was Moved to it's current location / section as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
tryingmybesthere:
No wonder. An Arduino port used as an input does not draw any significant current at all. :roll_eyes:
Well, if it is used with a pinMode of INPUT_PULLUP and connected to ground, it will supply approximately 100 µA corresponding to a pullup "resistance" value of approximately 47k.
