RGB LED Strip Changes with Button Push
Hi All,
I have a project with an LED Strip that I have been able to compile correctly but haven’t got the desired result. I have one of the older style LED strips, 12V with separate R, G and B channels. I’d like them to stay white when switched on, but do a rainbow transition effect when a button is pushed. The button is a reed switch, and using the serial monitor, I’ve been able to verify the signal is being received.
I am using a standard Arduino Uno and have the LED strip powered with a separate power supply. When switched on, the LED strip stays white when the button is pushed and no rainbow sequence is played. I think I have not written the code correctly to work for this, any ideas/advice are much appreciated.
// LED Strip
// This controls an LED strip to turn on white, and play a rainbow sequence when a button is pushed.
#define REDPIN 11
#define GREENPIN 10
#define BLUEPIN 12
const int buttonPin = 9;
int r, g, b;
  pinMode(REDPIN, OUTPUT);
  pinMode(GREENPIN, OUTPUT);
  pinMode(BLUEPIN, OUTPUT);
  pinMode(buttonPin, INPUT);
byte buttonState = digitalRead(buttonPin);
if (buttonState == HIGH) {
  Serial.println("Button On");
  Serial.println("Button Off");
  // fade from blue to violet
 for (r = 0; r < 256; r++) {
    analogWrite(REDPIN, r);
    delay(200);
  // fade from violet to red
  for(b = 255; b > 0; b--) {
    analogWrite(BLUEPIN, b);
    delay(200);
  // fade from red to yellow
  for (g = 0; g < 256; g++) {
    analogWrite(GREENPIN, g);
    delay(200);
  // fade from yellow to green
  for (r = 255; r > 0; r--) {
    delay(200);
  // fade from green to teal
  for (b = 0; b < 256; b++) {
    delay(200);
  // fade from teal to blue
  for (g = 255; g > 0; g--) {
    delay(200);
 else {
 for (g = 255; b = 255; r = 255);
  analogWrite(GREENPIN,g);
I think you had better show us the circuit you are using with your FETs to switch the LED strip and preferably, a photo for confirmation (photos always taken if full outside daylight but not direct sun, with perfect focus not less than 4 Megapixels!).
sjpiper145,
To me, it looked like you had a bracket out of place.
For me, I try to keep my logic together as much as I can, so allow me to suggest some slight changes. See attached code.
See if this works better. I can’t test because I don’t have those type of LEDs.
// LED Strip
#define REDPIN 11
#define GREENPIN 10
#define BLUEPIN 12
int r, g, b;
if (buttonState == LOW) {
  else {
    delay(200);
    delay(200);
    delay(200);
    delay(200);
    delay(200);
    delay(200);
