RGB LED strip for clock -- recommendations?
My goal is to make a clock / timer using push buttons and an LED strip.
I can do everything myself except for the LED strip. (That is, I know how to perform date/time calculations, how to install an RTC, how to install and debounce push-buttons, that kind of thing.)
I need an LED strip whose LEDs are spaced at least, say, 15 mm apart. For ease of reading the time, I need them to be RGB LEDs. That way, I could command every 5th or 10th one to appear in a different color, that sort of thing, I haven't worked out the details yet.
Once I have the LED strip, I need to be able to command it. I need to be able to tell an individual LED to turn a certain color until further notice. I would much prefer not to have to multiplex anything manually. If the strip has built-in hardware so I need not do this in software, so much the better. If I cannot simply command one LED individually, but rather must command them all at once, that is fine with me: it being a clock/timer, I need not do so more than once or twice a second. As long as I can specify a different color for each LED to turn, that is all I need. (Example: "seven minutes" might be indicated by turning the first five LEDs blue, the sixth and seventh LEDs green, and the remaining LEDs off.)
What LED strip do I get and where do I get it? What software do I use to drive it?
Please do not recommend Adafruit. Their Web site is too animation-heavy and it locks up my computer.
Yes you can, look on eBay, example here:
Hi, why is that? This means only 6 or 7 leds per metre. Strips are usually at least 30 leds per metre. If you want only 6 or 7 leds per metre you will have to make your own strips.
Paul
I would recommend using the FastLED library and any of the LED strips that it supports. WS2812 like LarryD suggests is a good choice.
Or just not turn on the LEDs in between, which is a waste but a viable alternative to making a strip.
PaulRB:
Paul
I said 15 mm apart, not 15 cm apart.
1000 mm = 1 meter
LED strips that I have seen come with 30 LEDs/m, 60 LEDs/m, or 144 LEDs/m.
You can do the math to see if they will meet your needs.
odometer:
1000 mm = 1 meter
So you did. Sorry!
