I have an 11m strip of 3528 RGB LEDs made up of two 5m segments and a 1m segment joined by solder traces, with connectors at each end.
When I apply 12V to either end, the LEDs closest to the supply are fine, but as you move down the strip every 2nd group of 6 LEDs starts to fade (first blue, then green, then red then all) to the point where at then end of the strip, every second group is not lit up at all.
Same phenomenon occurs regardless of which end you supply power. I took voltage readings at the two joints and get somewhere between 6-9V depending on the colour. My 12V supply outputs around 12.5V under load.
The perplexing part is that every 2nd group of 6 seems to be fine. I looked for a schematic to figure out how things were laid out but had no luck.
Any thoughts or direction on other troubleshooting I should do?
