RGB LED Strips control over Wifi
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <WiFiClientSecure.h>
#include "certs.h"
#include <LEDStripDriver.h>
// DIN=GPIO16, CIN=GPIO14
LEDStripDriver led = LEDStripDriver(16, 14);
char messageBuffer[50];
WiFiClient espClient;
PubSubClient client(espClient);
unsigned long currentTime;
unsigned long startTime;
String lastledcolor;
String ledcolor;
bool command=false;
void setup_wifi()
  Serial.print("connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
    pause(500);
  Serial.print("WiFi connected to ");
  Serial.print("IP address : ");
  pause(2000);
  setup_wifi();
  client.setServer(mqtt_server, 1883);
  client.setCallback(callback);
  led.setColor(0, 0, 0);
  if (!client.connected())
    reconnect();
  client.loop();
  if (command == true)
    Rainbow();
  else if (command == false)
    lastledcolor = ledcolor;
    stopRainbow();
void reconnect()
  while (!client.connected())
    if (client.connect("Reception"))
      Serial.println("connected");
      client.subscribe("RGB/Output");
    else {
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again");
void callback(char* topic, byte* payload, unsigned int length)
  //Serial.println();
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  Serial.print("length : ");
  Serial.println(length);
  memcpy(messageBuffer, payload, length);
  messageBuffer[length] = '\0';
  Serial.print("the payload is : ");
  Serial.println(messageBuffer);
  if (strcmp(messageBuffer, "change") == 0)
    Serial.println(strcmp(messageBuffer, "change"));
    command= true;
  else if (strcmp(messageBuffer, "freeze") == 0)
    Serial.println(strcmp(messageBuffer, "freeze"));
    command= false;
void stopRainbow()
  if (lastledcolor == "red")
    led.setColor(255, 0, 0);
  else if (lastledcolor == "green")
    led.setColor(0, 255, 0);
  else if (lastledcolor == "blue")
    led.setColor(0, 0, 255);
  else if (lastledcolor == "yellow")
    led.setColor(255, 255, 0);
  else if (lastledcolor == "cyan")
    led.setColor(0, 255, 255);
  else if (lastledcolor == "magenta")
    led.setColor(139, 0, 139);
  else if (lastledcolor == "orange")
    led.setColor(255, 69, 0);
  else if (lastledcolor == "pink")
    led.setColor(255, 20, 147);
void Rainbow()
  ledcolor = "red";
  pause(1000);
  ledcolor = "green";
  pause(1000);
  ledcolor = "blue";
  pause(1000);
  ledcolor = "yellow";
  pause(1000);
  ledcolor = "cyan";
  pause(1000);
  ledcolor = "magenta";
  pause(1000);
  ledcolor = "orange";
  pause(1000);
  ledcolor = "pink";
  pause(1000);
void pause(unsigned long period)
  currentTime = millis();
  if (currentTime - startTime >= period)
  {} startTime = currentTime;
Hello, I’ve programmed my google assistant on my phone to send MQTT commands “change” & “freeze”.
Currently the LED Strip lights up white in the setup, but Rainbow() & stopRainbow() are not working. How do I make colors change over Wifi?
aarg:
Can you please define “not working” in more detail?
The led does not change color is what I meant by not working. It just stays white
Your pause function does absolutely nothing. I reformatted it so you can see that.
This code:
void Rainbow()
  ledcolor = "red";
  pause(1000);
  ledcolor = "green";
  pause(1000);
  ledcolor = "blue";
  pause(1000);
  pause(1000);
  ledcolor = "cyan";
  pause(1000);
  pause(1000);
  pause(1000);
  ledcolor = "pink";
  pause(1000);
Is equivalent to this code considering pause does nothing and you keep overwriting ledcolor:
void Rainbow()
  ledcolor = "pink";
ToddL1962:
I made the pause to replace delay. I added the unsigned long period so it will do nothing for the specified period of time. As for ledcolor I'm using a strip driver module. So I'm following the example RGBtest.ino from this link GitHub - MrKrabat/LED-Strip-Driver-Module: Arduino library for the full color RGB LED strip driver module shield
Professor_Joe:
OK. That is not what it does, however.
Please do not answer posts by going back and editing your previous posts. That messes up the continuity of the thread.
Just quote, or not quote, and answer.
Professor_Joe:
He uses delays and does not have an ledcolor String variable that he overwrites.
I heard delay() slows down MQTT response time which is why I created pause().
Professor_Joe:
That's because the callback is called from the client.loop() method. Any delays in loop() will delay your callbacks. Whatever your reason for creating the pause() function it does nothing. Even if it did work it would not solve that issue.
I would suggest restructuring your code to use the command flag and set a counter to sequence you through the rainbow and pauses every time you go through loop().
ToddL1962:
whats a command flag?
Professor_Joe:
I was referring to the command flag you already created.
Here is a version of your code which does what I described:
#include "certs.h"
const unsigned long pausePeriod = 1000;
bool command=false;
bool pause=true;
const int numLedColors = 8;
int ledSequenceCount = 0;
void setup_wifi()
    Serial.print(".");
    pause(500);
  pause(2000);
  setup_wifi();
    reconnect();
  client.loop();
  if (command)
    if (pause)
      if (currentTime - startTime >= pausePeriod) pause = false;
      switch (ledSequenceCount)
        case 0:
        case 1:
        case 2:
        case 3:
        case 4:
        case 5:
        case 6:
        case 7:
      startTime = millis();
      pause = true;
      ledSequenceCount++;
      ledSequenceCount %= numLedColors;
void reconnect()
  //Serial.println();
  Serial.print("] ");
    command= true;
    command= false;
I can’t compile or test it but you can try it. When the command flag is set every iteration of loop either sets a new LED color or executes a pause between LED colors. That way the callback can be executed without getting delayed. When the “freeze” command is received the sequence freezes, when the “change” command is received the sequence picks up where it left off.
Here is another way to do it using an array for the LED colors:
#include "certs.h"
bool command=false;
bool pause=true;
byte ledTable [numLedColors][3] =
{{255, 0, 0},
 {0, 255, 0},
 {0, 0, 255},
 {255, 255, 0},
 {0, 255, 255},
 {139, 0, 139},
 {255, 69, 0},
 {255, 20, 147}};
void setup_wifi()
    Serial.print(".");
    pause(500);
  pause(2000);
  setup_wifi();
    reconnect();
  client.loop();
  if (command)
    if (pause)
      led.setColor(ledTable[ledSequenceCount][0], ledTable[ledSequenceCount][1], ledTable[ledSequenceCount][2]);
      pause = true;
      ledSequenceCount++;
void reconnect()
  //Serial.println();
  Serial.print("] ");
    command= true;
    command= false;
So I'm following the example RGBtest.ino from this linkYeah i do have one of those units as well, and i suppose if you are just sending a single pixel the library works. You can daisy chain those and address each unit individually.
ToddL1962:
#include “certs.h”
bool command=false;
bool pause=true;
{{255, 0, 0},
{0, 255, 0},
{0, 0, 255},
{255, 255, 0},
{0, 255, 255},
{139, 0, 139},
{255, 69, 0},
{255, 20, 147}};
void setup_wifi()
  Serial.print(“connecting to “);
    Serial.print(”.”);
    pause(500);
  pause(2000);
  setup_wifi();
    reconnect();
  client.loop();
  if (command)
    if (pause)
      pause = true;
      ledSequenceCount++;
void reconnect()
    if (client.connect(“Reception”))
      Serial.println(“connected”);
      client.subscribe(“RGB/Output”);
      Serial.print(“failed, rc=”);
  //Serial.println();
  Serial.print(“Message arrived [”);
  Serial.print("] ");
  messageBuffer[length] = ‘\0’;
  if (strcmp(messageBuffer, “change”) == 0)
    Serial.println(strcmp(messageBuffer, “change”));
    command= true;
  else if (strcmp(messageBuffer, “freeze”) == 0)
    Serial.println(strcmp(messageBuffer, “freeze”));
    command= false;
I’ve tested this code works thanks a lot
