Hi All,
I have a commented script which will allow you to alter an RGB LED w/ a Potentiometer.
I’m a noob at this and had a tough time figuring out how to use an RGB LED, so i figured i’d comment this script for others. Here is the script and comments to help out anyone else that is looking to do similar.
RGB LED w/ Potentiometer
This script will allow a potentiometer to adjust the RGB values of an RGB LED to adjust it's color.
It will also output values to the serial monitor to view the values. (Potentiometer value, Color Hue degree, RGB values)
Components used:
- Arduino Duemilanove
- Solderless Breadboard
- Easy wire connectors
- 5mm High Brightness Full-Color LED (4.0V max green/blue, 2.6V max red)
- 10kom Potentiometer
Quick Fact:
- An RGB LED is actually made up of 3 tiny LEDS inside of one!
- Pot = Potentiometer
The circuit:
* Potentiometer connected to analog pin 2 w/ pos 5v and grounded neg
* RGB LED connections are in this order when looking at LED: Red, Common Annode(Longest - also where 5v power is connected), Green, Blue
* RGB LED attached from digital pin 9(red), 10(green), 11(blue) w/ common annode to 5v power.
Created 8 May 2010
Commented by Dave a.k.a Ka0ticstyle
int potpin = 2; // POT connected to digital pin 2 - pos/neg are left and right connections on POT
int rpin = 9; // Red
int gpin = 10; // Green
int bpin = 11; // Blue
float h; // Hue range
int h_int; // Hue color
int r = 0, g = 0, b = 0; // Default RGB values
int val = 0; // Set POT value to default 0
void h2rgb(float h, int& R, int& G, int& B); // Instantiate h2rgb and it's variables a.k.a Hue to RGB
void setup() // Run once, when the sketch starts
Serial.begin(9600); // Begin the output of data to serial
void loop() // Run over and over again
val = analogRead(potpin); // Read the pin and display the value
h = ((float)val)/1024; // Get the range. pot value / 1024
h_int = (int) 360*h; // Get the color hue by multiplying by 360
h2rgb(h,r,g,b); // Call the h2rgb function passing it the hue value
Serial.print("POT value: ");
Serial.print(val); // Pot value
Serial.print(" = Hue of ");
Serial.print(h_int); // Color Hue value
Serial.print(" degrees. RGB values: ");
Serial.print(r); // Red value
Serial.print(" ");
Serial.print(g); // Green value
Serial.print(" ");
Serial.println(b); // Blue value
analogWrite(rpin, r); // Changes red led
analogWrite(gpin, g); // Changes green led
analogWrite(bpin, b); // Changes blue led
void h2rgb(float h, int& R, int& G, int& B) {
// Used HSV --> RGB function
// HSV - Hue, Saturation, Value
// RGB - Red, Green, Blue - example (255,255,255)
// Function below does a bunch of math to convert HSV values to RGB
int var_i;
float S=1, V=1, var_1, var_2, var_3, var_h, var_r, var_g, var_b;
if ( S == 0 ) //HSV values = 0 ÷ 1
R = V * 255;
G = V * 255;
B = V * 255;
var_h = h * 6;
if ( var_h == 6 ) var_h = 0; //H must be < 1
var_i = int( var_h ) ; //Or ... var_i = floor( var_h )
var_1 = V * ( 1 - S );
var_2 = V * ( 1 - S * ( var_h - var_i ) );
var_3 = V * ( 1 - S * ( 1 - ( var_h - var_i ) ) );
if ( var_i == 0 ) {
var_r = V ;
var_g = var_3 ;
var_b = var_1 ;
else if ( var_i == 1 ) {
var_r = var_2 ;
var_g = V ;
var_b = var_1 ;
else if ( var_i == 2 ) {
var_r = var_1 ;
var_g = V ;
var_b = var_3 ;
else if ( var_i == 3 ) {
var_r = var_1 ;
var_g = var_2 ;
var_b = V ;
else if ( var_i == 4 ) {
var_r = var_3 ;
var_g = var_1 ;
var_b = V ;
else {
var_r = V ;
var_g = var_1 ;
var_b = var_2 ;
R = (1-var_r) * 255; //RGB results = 0 ÷ 255
G = (1-var_g) * 255;
B = (1-var_b) * 255;
Hope this helps!
