RGB led with EEPROM
Kod jsem upravoval z internetu.Chtěl bych ,aby při stisku tlačítka se přehodil mod a při tak 5 sekundach se uložil do EEPROM ,a pak už neukládal znova ve smyčce po 300mil/sekund.
#include <EEPROM.h>
const int buttonPin = PB3;
const int redPin = PB0;
const int greenPin = PB1;
const int bluePin = PB2;
byte mode;
  pinMode(buttonPin, INPUT_PULLUP);
  pinMode(redPin, OUTPUT);
  pinMode(greenPin, OUTPUT);
  pinMode(bluePin, OUTPUT);
 mode = EEPROM.read(10); //priradím byte hodnotu z EEPROM z ofsetu 10 k premennej mode
  int buttonState;
  buttonState = digitalRead(buttonPin);
  if (buttonState == LOW) {
    mode++; //mode+1
    delay(250);
  else if (mode == 0) {
    digitalWrite(redPin, LOW);
    digitalWrite(greenPin, LOW);
    digitalWrite(bluePin, LOW);
  else if (mode == 1) {
    digitalWrite(redPin, HIGH);
    digitalWrite(greenPin, HIGH);
    digitalWrite(bluePin, HIGH);
    EEPROM.update(10,1);
    delay(300);
  else if (mode == 2) {
    digitalWrite(greenPin,LOW );
     EEPROM.update(10,2);
    delay(300);
  else if (mode == 3) {
    digitalWrite(greenPin,HIGH);
    digitalWrite(bluePin,LOW );
    EEPROM.update(10,3);
 delay(300);
   else if (mode == 4) {
    EEPROM.update(10,4);
     delay(300);
   else if (mode == 5) {
     EEPROM.update(10,5);
      delay(300);
   else if (mode == 6) {
    EEPROM.update(10,6);
     delay(300);
   else if (mode == 7) {
     EEPROM.update(10,7);
      delay(300);
  else {
    mode = 0;
    //EEPROM o tejto hodnote nevie, lebo ju tam nezapisuješ, ostane nastavena v EEPROM 7 a nasledne po inkrementacii skoci na 1.
Language problem ?
Try a language closer to your native language:
Thanks to all those who helped and added to this list.
[/quote]
I will take a SWAG, I think you are trying to control the EEPROM writing to extend its life. You are using the Update command which actually reads the location and does not write it unless the new value is different. You can write the same value thousands of times without any EEPROM writes taking place.
So you need to save the value of 0 there as well like you do for the other modes.
  else {
    mode = 0;
    EEPROM.update(10, 0);
    delay(300); // ??
You can make your code a lot shorter by placing EEPROM.update in the button 'handling'.
  int buttonState;
    mode++; //mode+1
    EEPROM.update(10, mode);
    if(mode > 7)
      mode = 0;
    delay(250);
    delay(300);
    digitalWrite(greenPin, LOW );
    delay(300);
    digitalWrite(bluePin, LOW );
    delay(300);
    delay(300);
    delay(300);
    delay(300);
    delay(300);
  else {
    // nothing to do
Note:
I do not know / understand what you want to do with the 5 seconds.
