Hi everyone, I have a question, related to rgb led, in my work I need to put two alternating colors, like the police siren, and I do not know how to do it, when I try, it makes a junction of the two, like magenta
Thanks.
(deleted)
float TempC;
float TempC1;
float TempC2;
int tempPin1=1; //sensor
int tempPin=0; // sensor
int tempPin2=2; //sensor
int Rled=9;
int Bled=10;
int Gled=11;
void setup () {
pinMode(Rled,OUTPUT);
pinMode(Bled,OUTPUT);
pinMode(Gled,OUTPUT);}
void loop () {
TempC= analogRead(tempPin);
TempC= ((5.0TempC100.0)/1024.0);
delay (1000);
TempC1= analogRead(tempPin1);
TempC1= ((5.0TempC1100.0)/1024.0);
delay (1000);
TempC2= analogRead(tempPin2);
TempC2= ((5.0TempC2100.0)/1024.0);
delay (1000);
if (TempC>80) {
analogWrite(Rled,255);
analogWrite(Bled,0);
analogWrite(Gled,0);
analogWrite(Rled,0);
analogWrite(Bled,255);
Is your RGB LED common anode? If so a 0 will turn on a color and 255 will turn it off. So when you think that you are turning on the red LED, you actually are turning on green and blue (cyan).
is cathodo
And with a resistor in each anode?
yes
Have you tested the LED to turn on all colors one at a time?
Did this work?
Try a bigger delay between the two states. You have half a second at the moment maybe that is too fast for your eyes.
